Straight Chassis
2006 workshop manual says 31L engine cooling and 19L supercharger cooling.
For the supercharger "Less than 80% of coolant capacity can be recovered with the engine in the vehicle."
zo6cammer
New member
Feb 3, 2014
3
that blue is the best combo, love it
Very happy today. Engine fired up, everything working except the odometer Air cond man is coming tomorrow to gas up the system intercooler system only took 8 litres,, Drivers manual says it hold 17litres.. Only got 20 litres into the cooling system, manual says 25litres,, haven`t really warmed it up yet, so I guess when the thermostat opens it will want some more, but not sure about the intercooler,, Have bleed the system and run the pump,, no bubbles.. Anyone know for sure how much the intercooler system hold,, Cheers
Did you use a vacuum system to fill them? If not you probably have a lot of air in the lines.
shesgotlegs
1,183
Huge undertaking to say the least. Well done and getting closer!
ultrasportracing
492
Perth Western Australia
Didn't use a vacuum system to fill them, just followed the manual advise for non vacuum method..AS I bought a second hand engine, Can only assume there was coolant in the block and engine intercooler. Def no air in the intercooler circuit,, bleed heater, that got another litre..
JAYGT
175
MIAMI
What a monumental task! My hat's off to you sir.
ultrasportracing
492
Will run a vacuum unit over it and see what happens,,
Ultrasport,
You are obviously very a talented fellow!If this is what you do for a hobby,what do you do in your real world?I’m thinking engineer? Thank you.Very enjoyable postings!
I bet you could chat with Rich and Dennis (THE GT GUYS) for hours!
They are the only others who could accomplish that task!
ultrasportracing
492
Vacuumed both systems, no air present.. must have been residue in the engine and intercooler.
ultrasportracing
492
rebuild
Dash top completed, off to the upholsteries. Test drove today. only quick run, no windscreen fitted yet. Wow well worth all the effort,, Just have to get the ABS configured and fix the odometer. When the upholsteries down can fit windscreen and refit the front end,, cant wait. To Rocketman, Just a kiwi spannerman, been building car stuff since I was 10years old. It is amazing what you learn along the way..
I think you are being modest to say the least! Either way I have really enjoyed your build process .! My hats off to you! Perhaps you could come join us in Vegas? We would love to meet you in person!Your due for a holiday!
ultrasportracing
492
odometer
Very relieved today. Odometer now working. did all pinpoint tests, everything checked out ok, lightly scrubbed terminals, with a small pic, reconnected and a miracle appeared.. numbers on the odometer and trip meter.. As you know these parts are very expensive, so I can carry on.. One last problem the ABS is not working, the brake pedal is very hard, The booster has vacuum so more pinpoint testing tomorrow. Cant believe, these are the only problems after a ground up rebuild.. So very happy, cant wait to do more driving. as that is the whole point of the exercise, cant see the point of having one or more just for arts sake. Yesterday was the first time the car has sat on the ground with bodywork on it,, They look so sexy.
I am more and more impressed by your ingunuity !but you must know we need some more picture , like a lot more !
Also expecting some iPhone video or your first drive . I'm sure you must be able to find a volunteer to assist you!
Did I mention more pictures !
Your thread is a breath of fresh air,due to the loss that we have just experienced.
No pressure!!!
ENJOY your first ride !
That's truely a special moment
My best regards, Ron Aka Roketman
ultrasportracing
492
second drive
Wheel alignment done, steering straight. Will have to get my daughter to video me. Although have no idea how to put it on here, Just waiting for the dash top to come back from the upholsters, then windscreen can go on, then the front.
Anyone had the front off, Are the 3 rods that hang done from the front chassis section sandwiched between the front bumper and the under tray, as the bolts go in from the bottom . Was thinking of making 3 stronger supports
mmlcobra
1,224
Amazing job!
Congrats.
Car gets looks on its own, but in that condition on the street you must REALLY get some looks.....
Really been fun keeping up with this thread. Great work.
AMB
401
San Diego,Ca.
Abs brake bleeding
When I changed the brakes on my 03 Cobra; I had to bleed the system with the "ENGINE RUNNING" !!! :confused
Make sure you seal around the rad pack to insure max air to the radiators
Looks great keep sending pictures!
I was expecting some old guy!
LOL
SaskGT
47
Yes the 3 rods are sandwiched between the sheet metal (that has the clip nut) and the chin spoiler.
I enjoy the pictures, incredible amount of work.
ultrasportracing
492
console
Fabbed up a new opening console lid, another job for the upholsterer
