Goodbye Bridgestone Scuderia Rear Tires??
Well, when you're following Ed Sims and roketman, it's hard to stay back when they are always on their brakes. :lol
I have two commemorative stone chips. One from a dump truck on the bridge from NO to NOLA at Rally 7. One from Ed Sims on the post-Rally 8 Rally heading to Lake Tahoe. They both bring back great memories.
I stay in front of Ed Sims in the freeways, but well behind him on the twisty roads.
...I have two commemorative stone chips....
At least they're not in your windshield (I hope)...
No offense, Barry!
Yes, they are. I don't count stone chips on the body.
Tomcat
Ordered rears from Onlinetires.com
Delivered in a week.
02/14 production code
That's great. Very new stock.
Tomcat
They look huge. Anybody have a detail picture of how much the sidewall will bow on stock BBS (upgrade/option) wheels compared to Goodyear F1s?
Post 477 http://www.fordgtforum.com/forums/showthread.php/12372-THE-Tire-Thread/page48 Other pics are in that thread.
partssmann
772
Tomcat, look at my post #88 in this thread. Not much sidewall bow at all. Tire tech was concerned but after mounting thought they looked ok. Only advice I got from others was to run the tire pressure at 30 psi to avoid excessive tire wear in the middle.
I have mounted a set of these Bridgestone tires on standard FGT wheels and they look and fit great. While they don't offer the grip of the Hoosier R-6 tires I use most of the time they are a big improvement over the Goodyears and because they are wider they look better. I didn't have any desire for a set of these until I read this damn thread. As soon as I'm told I can't get or have something I automatically go out and get some. Now I have 4 sets of wheels and tires. Good grief.
On the plus side, the Bridgestones can sit for months without going flat and that's handy. R-6's loose air pressure a lot faster than normal tires. Cheers.
Do you use nitrogen instead of air?
I have read all of the stories about how Hoosiers don't hold air as well as street tires. So before I had mine mounted I carefully inspected them and noticed a lot of molding spruces left on the beading surface. I pulled all of them off of all 4 tires, what a PITA! I don't know if I was just lucky or if pulling off the molding spruces did something, but all 4 of my Hoosiers hold air as well as any street tire I have owned. YMMV.
I do, I have a bottle in the shop. It is also air while trailering, or at track. easier to add air to tires than starting a compressor. Of course also will have less moisture, unless you have a high end compressor.
Tomy,
I just use air. I have a compressor in my garage and thats what I use.
Ice,
That is great info. I'm going to dismount a set and do the same thing to see if that helps. I have put the mounted tires under water and I can never see where the air is seeping out. Thanks.
10 lb CO2 bottle. Used mainly for airing up after off-roading the 4WD, but always carry in the trailer while traveling.
Tomcat
Thanks guys!
HIRISC
259
Minneapolis, MN
That is a very nice picture HIRISC.
HIRISC
259
Minneapolis, MN
Thanks brother.
Pic from a photoshoot with a photog. friend of mine, Alex Bellus:
http://s93.photobucket.com/user/HIRISC/slideshow/FordGT/PhotoShoot
