Speedometer and Tach rebuild
ttn27
38
It may not be a check engine light? The check engine light is a yellow light with an engine icon. The "Check Gauges" light is red and has been confused with the check engine light frequently. Do you have a yellow check engine light? In answer to you question, a gauge problem will not trigger a check engine light.
It is the yellow check engine light
ttn27
38
Check engine or check gauges light? They're different. Check gauges means to look at gauges, something is up. Mine comes on for low fuel. Check engine sets with a code so check codes. I just finished getting a 3800 miler road ready. A ground on drivers side of engine, on frame, down low was loose. Just something to check everybody.
Almost any car parts place will read the code.
Or you can buy a bluetooth OBDII reader from Amazon for about $20 and get a phone app (I use Torque Lite) and it'll tell you lots of other useful things (like progress for the drive cycle tests) and has some real-time logging.
Is the light still on or did it go away after another key cycle?
ttn27
38
I already have a blue tooth OBDII reader that will read all the other cars, but for some reason it did not read the FGT, may be the app did not have a choice specifically for the FGT. Will try to get a better reader and see. The light did not go away with a another key cycle.
See my note before. Multiple coincident failures usually have a common source. As Rob also counseled, check battery ground and frame connections. Yours won't be the first.
bzambranog
29
If anyone needs a brand new tach I happen to have 2 of them in OEM packaging.
Hi! Do you stilll have them available?
aaronlstiles
New member
Mar 24, 2014
Utab
Do you still have any avaliable?
I am guessing he does not. I bought one and another member the other one. Right after he posted this.
bzambranog
29
And do you have a spare one? :)
Yes I do. It is not for sale.
