Speedometer and Tach rebuild
peloton
4
I've now put 190 miles on the speedo Rich repaired and it continues to work perfectly.
Rick Mustang
111
Central Texas
What’s the plan for the test phase and rollout of the permanent fix?
Steve Schneider
137
Yes I would have interest is the speedo rebuild
white out
111
Update: zero issues on my pair.
Still love the sweep at start up.
Mullet
2,468
05 white with blue stripe and 4 options……perfect and the fastest combo. 😁
thegtguy
*Supporting Vendor* GT Owner
Apr 20, 2006
552
MI
Just to update all of our testing has been going great and we are ready to proceed, so we are accepting parts for rebuild now. Cost will be $1400 per gauge and please allow 2-3 weeks for turnaround.
If you are interested, please send me an email (richgtguy@gmail.com) and we can get the process started.
drilling
395
is it better to buy a new oem cluster vs. have it repaired by rich?
OEM parts will fail with the same frequency as the one in your car...
For small gauges get the replacements directly from Auto Meter. They are OEM form-fit-function but have a redesigned innards.
For big gauges your choices are Rich's repairs OR the entire gauge panel from Speed Hut.
You’re probably not going to find a cluster and probably not a Tach or Speedo unless they’re used. As Tony said, you want the reissue Autometers anyway.
But it sounds like you can rebuild the bigs now so a least that’s an option.
drilling
395
Thank you! So no point in getting the new speedo from ford. Better and cheaper to have rich fix the gauges.
I had a Speedo on backorder with my Parts dealer and after a year of waiting they gave up and gave me my money back. I did get a Tach after about 9 months of waiting.
Now that there is a fix, better source a used one now before their core value shoots up.
Reactions: dshears
Stef
1,112
Intermittent gauge behaviour, especially if they recover after running for a while and restarting the engine, is caused by a marginal battery. Have you confirmed the battery is OK?
Secondly, I think that Rich's request is for people to test here and now, not for someone that will "get back to you in the spring"...
Had a 'marginal battery' situation happen yesterday. The only gauge remaining working was the Fuel gauge.
Talk about being upset, a real gut punch.
I went on my drive anyway because the car is well maintained all liquids are at proper levels etc.
After I got back in I shut of the ignition, had to arrange things in the shop and when I restarted the car to pull in all the gauges came back to life.
Before this yesterday, two of the gauges were already dead
(Alt & Vacuum)
I have been wanting to change those two out but now I'm thinking to just do the entire cluster of small gauges and see what happens with the Speedo and Tach.
I know, "If it ain't broke don't fix it"
but the eventuality of the OE gauge failing and all.
I like doing my own work
(whenever possible and if I can handle it)
Are the gauges a difficult job to do?
My better judgment tells me to have someone like Rich do the job.
Joe Dozzo
777
Canon City, CO
Gauges are not that difficult a job. I've had the panel out several times replacing gauges and testing another vendors (now discontinued) solution.
There is a nice description here:
https://www.fordgtforum.com/forums/threads/gauge-replacement-how-to.20781/
FWIW - my Autometer vacuum bit the dust last year...
Stef
1,112
Thanks, much appreciated!
Stefan
I am sure Rich would do it for free if he got the new GT Garage plastered for free.
Gene Cassone
1,019
way upstate NY
Rich did my small gauges in 2016. I watched him remove the dash. He knows “ the angles” and how to pull! I later did it myself, getting the dash with gauges out can be challenging! Make sure you use allot of painters tape!!
(Alt & Vacuum)
I let my local Ford dealer install a new fuel gauge a few years back. The technician scratched the hell out of the leather dash. So off my GT went to Rich’s to get the dash reskinned and while it was there I had him replace all the small gauges with new revised Autometer OEMs. All of the small gauges are still working perfectly. I’m probably about to jinx myself but I’m still running the original Speedometer and Tach. Knock on wood.
I changed mine to Speedhuts myself. Not a bad project. Will be sending my OEM dead ones to Rich over the summer to have them fixed.
Reactions: Stef
But only the speedo and tach go to Rich. Get the small gauges directly from Autometer. If you have bad small gauges and have the panel out it is suggested to replace them all - the cost isn't that much.
If you have a bad big gauge, I wonder if it is worthwhile to preemptively have the other one done too? I had my gauges out to replace one too. It wasn't too intimidating - just take your time - but if you have a shop do it it's all labor and the price to get both gauges bullet-proofed is maybe worth the extra cost while it's all apart. Rich, what do you think??
Rich rules!
Nice job and effort!
As usual!
