Speedhut gauges for our FGT's
AMB
401
San Diego,Ca.
Speedhut Gauges/Stock Gauges
Can they repair/replace the Stock Gauge Electronics, with their Electronics ??? :confused
427Aggie
885
Frisco, Tx
I'm in with AMB. Can they replace the guts of our gauges? I like the tac with the flat bottom and would be in for a set if they can replace the guts.
racelance
699
Carlisle, PA
Sign me up if they do!
Lance
I would be surprised if they would rebuild the OEM gauges when they have an on the shelf replacement that comes with a great warranty. :confused
If you just wanted to go that route, I'd buy an Autometer gauge and switch out the guts. I bet its pretty generic stuff, tho nobody at autometer will comment. The bezel on the stock gauge isn't a piece of cake to slip off. It may end up causing more cosmetic damage than you could live with.
Also, they said they identified something on the stock gauge controller board that took a voltage spike. They did not say that their equipment would be able to handle the such a voltage spike, only that they would warranty (lifetime) the hardware if it occurs.
When I dissected a few gauges, I could find no obvious evidence of a voltage spike and because the circuitry did not bare any markings it made testing individual chips all but impossible (for me). I am sure they are much better equipped to test these things.
FordGTOC
62
Flagstaff, AZ
I'll pass on what SpeedHut said via e-mail. I have a bad volt meter and asked via their onsite e-mail whether the SpeedHut replacement will fit the stock (OEM) dash panel. The answer was "yes" it will fit perfectly, and they confirmed that you can order the replacement gauge with the silver bezel to look more like stock. So you can buy the whole set, in which case you need their dash panel insert, or you can replace your dead gauges (other than the Tach and Speedo) and use the OEM panel.
427Aggie
885
Frisco, Tx
What im wondering is if there is a way for them to cut the back side of a stock speedo and tach and put their guts into them?
Jason Watt
Had both, sold both
1,229
Copenhagen, Denmark
Hi guys,
Just logged on after some time away.
The reason for my visit being that my battery went dead and after replacing and conncting my charger my speedo has gone quiet.
This thread popped up when searching "speedo dead" and it has been very intersting reading.
I have a few points and questions to ask my fellow GT'ers...
1. Is a speedo fixable? (I suppose not but have to ask)
2. These Speedhut gauges looks very sweet, but how about at night - I would hate if they didn't match the original blue/white light.
3. running a TT setup I would be far more interested in having a air/fuel gauge in place of the volt meter - anyone going in that direction??
And least - anyone goining for these new gauges and wanting to sell their OEM speedo??:biggrin
Give that man a 'ceeegar'. 'Been wondering the same thing...
t32b
Verde
432
Bay Area, CA
What do do?
I've followed this thread closely along with many of the more troubling gauge-failure-related threads in the past. I now have a gas gauge out. I woke up the car some time ago after returning from a three-month biz trip to find that the oil-pressure and gas-gauges were no-op. After replacing the battery (as I recall, the car was on the Tender) and ensuring good contact at the chassis ground my oil-pressure gauge is working but the gas gauge did not recover.
So, some simple questions:
1. The gauge is stuck at 'full'. Is this a common gauge failure mode or (gulp) could I have a problem with the tank float (or somewhere in between);
2. If only one gauge is out (and one started working after a battery fix), what is the chance that it is the gauge controller;
3. What it the best way to diagnose? I'd rather not send the car out for something like this, but I don't like driving with any 'faults'. Shall I just order a replacement OEM gauge and start from there? Torey (sp?)
Thanks,
Rich
Your gas gauge could be stuck at any level. It won't come back and it's not the float (it's ultrasound).
PeakCompletions
Boost is an addiction...
1,414
West Texas
anyone have a carbon fiber backplate for these gauges?
Superfly
HERITAGE GT OWNER
2,210
PeakCompletions
1,414
West Texas
sweet!!! thanks for the link!
I took the old gauge cluster and made a cool piece of office furniture out of it.
racelance
699
Carlisle, PA
Awesome!
Great idea...
