http://www.speedhut.com/fordgt.htm
Sorry no pics, I'm on an iPad.
From the site:
Ford GT dash
We are proud to announce indash OEM factory gauge replacements for the Ford GT! These exciting new gauges will be direct plug-n-play to the Ford wiring harness and require no additional sensors or wiring!
Speedhut will be offering these new gauges individually or as an entire replacement kit. A replacement aluminum panel, available in black or silver grained powder coat finish, replaces the factory panel to hold your new GT gauges. This new aluminum dash panel is a direct OEM replacement fit to the Ford GT dash.
Easy gauge plug-n-play works with the factory Ford wire harness. Each gauge is ONLY 1.1" deep for easy installation in the Ford GT dash.
One of the exciting features of the gauges is the included warning light that will light up a bright red color to indicate potential engine trouble or a low fuel indication. The tachometer has 5 integrated, bright LEDs, that light up at a user setable shift point.
Just like all our gauges, YOU will be able to customize these new Ford GT gauges to the colors and bezel style you would like at no extra cost!
Ford GT Gauges List price
Speedometer $225.00
Tachometer with Shift Lights $265.00
Boost $190.00
Oil psi. $190.00
Volts $190.00
Water temp $190.00
Fuel level $190.00
Aluminum Dash insert (silver or Black) $120.00
From the site:
Ford GT dash
Speedometer $225.00
Boost $190.00
Oil psi. $190.00
Volts $190.00
Water temp $190.00
Fuel level $190.00
