Motorcraft 5W-50 full synthetic
Oil change today with Rotella. Some time ago, I found this on Wikipedia. You can find various similar versions on the web. My car has long tube headers. Based on this, I would not have used the Rotella with catalytic converters in a state with tough emissions inspections. IDK why diesel engines with cats would be any different, but I didn't pursue the issue with Shell.
Sorry, that png file doesn't display full size. Here's the essential text:
"Rotella oils are not recommended for gasoline vehicles with catalytic converters.
Best regards,
Shell Technical"
Dated 11/13/13
Xcentric: Diesel cats work differently than gasoline cats. I also suspect that diesel was exempted from the reduced zinc and phosphorus requirement due to its primary use in truck engines.
Beach-GT
887
Seminole Florida
We don't need no stink'in CATs.
DakotaGT
1,730
Sioux Falls, South Dakota
After perusing all of the oil threads, I must dredge the topic back up again. It has now been several years since many members have started using the Rotella T6 5w-40 synthetic engine oil. I “get” the argument about the integrity of the viscosity holding up over time, but still hesitate regarding the higher ZDDP levels in the Rotella T6. I am still running with cats. Has anybody heard of a GT or GT500 5.4 with verified O2 sensor or cat failures from the Rotella T6? I don’t care about the price difference between oils- just want the best option. With as few miles as I accumulate on my cars, it probably barely matters. After reviewing the topic extensively, I’m inclined to alternate between the Motorcraft and the Rotella with oil changes. :cool:
Cobraguy
I have been using T6 oil in absolutely every vehicle I own right down to my forklifts. Most of them see relatively few miles annually due to our short driving season. Re your O2 sensor question......I’ve only had one intermittently send a code and that is on my old Yukon with 335k on it. its been on T6 since day one and does not use a drop of oil and when changed at 8,000 km intervals the oil looks clean enough to reuse. My DD Roush Raptor is started up in temps down to -40’ with no issues.
Nothing scientific noted here and no recommendations made either way.....just one man’s experience.
Reactions: DakotaGT
You’re probably not going to live long enough nor put enough miles on your car to damage the cats with T6. I use it in everything except a motorcycle and the NFGT. 190k miles on one vehicle and no problems whatsoever.
Reactions: Nafod and DakotaGT
DakotaGT
1,730
Thank you, gentlemen! I appreciate your thoughts on the matter.
