Are you driving back to home or arranging transport? Just buy a new battery at AutoZone or oreilly locally and put it in. If oil and brake fluid are in good shape you should be ready to go. Look at tires. If the original good years, just take it easy until you can get bridgestones
Replace it. Easy. Do not lean on fenders!Arranging transport. Whats the chance of flat battery? If I have them hook it up to trickle charger is that safe?
How easy is it to replace battery?
It has speedhut gauges. Still dont risk it right?You certainly can hook to it to trickle charger. Not a good idea to jump start. The most important thing is to protect the guages
If by "arranging transport" you mean hiring somebody, and they might need to replace the battery, that's kinda scary ... Makes sure they know Do Not Let Elbows Touch The Fenders!! ... otherwise, dingArranging transport. Whats the chance of flat battery? If I have them hook it up to trickle charger is that safe?
If by "arranging transport" you mean hiring somebody, and they might need to replace the battery, that's kinda scary ... Makes sure they know Do Not Let Elbows Touch The Fenders!! ... otherwise, ding![]()
Now I am anxious the battery is dead and it will be a headacheI wont. Can I just hook it to a ctek charger for few hours prior and hope for the best?
Yes, def try that first.I wont. Can I just hook it to a ctek charger for few hours prior and hope for the best?
I don't think I have enough experience / knowledge to competently answer you. I "want" to say, 'Yes it's safe, since you don't have the OEM gauges', but someone else needs to reply here to say whether or not the ECU could be at risk, or anything else. I doubt it, but def not sure. Yeah, remove the trunk liner to get to the battery.My transport guy said that he has battery pack. Is it safe to do this? I should remove the frunk liner and access the battery right?
EXACTLY!So do not push these area too hard with elbow or it will cause a dent right?
