Help Needed with Oil tank bolt
Lorenzo
626
U.S.A.
If you dont already have the magnetic drain plugs that are offered by one of our forum members then you should get all three anyway.
Yes i would expect to see a melted O ring when the plug comes out.
I would use an impact. I think it is your best chance. The trick is that you cannot use an extension. An extension will buffer out all of the hammer blows making the impact ineffective. Can you get a small 3/8" impact up there? I think it would come right off if you could.
The worst case scenario isn't so bad, anyway. In the worst case you muck up the reservoir - but then it would be relatively easy to have another bung welded on and the whole tank can re re-coated, no problem.
paul b
810
After looking at the manual, removing the resevoir doesn't look too bad. Once removed either the impact or drilling out would be easy. For a couple of hours work you could save $1500.
AJK
336
Is this really a result of over tightening or is it a marraige of the metals over time ?
AJK
sandman
465
Gardnerville, Nv.
Guys guys, think about it, there is an o ring on the drain plug. WD-40 and other magic stuff is not going to get past the O ring to work on the threads. The same in reverse, the oil in the tank dosent get past the O ring thankfully keeping the oil from leaking out.
HERE IS YOU BEST OPTION, Your local Snap-on dealer has these on the truck,Get him to demo this tool for you. I have one and i promise you it will work and you will be pleased.
Watch the u-tube, Its not a gimmic it Really works.
http://www.youtube.com/watch?v=_YO_snrzYrs&feature=player_embedded
Very cool tool Larry, I need one!
Propane torch to heat the tank bung followed by a 1/2'' impact (3/8 gun didn't do it) with a 3 inch extension worked for me. I tried a 24'' 1/2" rachet with a 3'' extension to clear the frame caused too much deflection and couldn't break it loose. Removing the tank isn't a big deal but would not be any easier imo as you would have to secure the tank without damaging it in the process.
freeflyer
GT Owner/ Forum Sponsor
180
Montana
Damn, another cool and useful tool....it's on the way here now. Thanks Lorenzo.
SMOKDU
412
update. Drain plug is out. i used a 1/2 electric impact from DeWalt with no extension. All is good oil is back in the car. Just an FWI i sucked all the oil out of the tank from the top (I thought) and at least 3 more quarts came out the bottom. Thx Guys.
Did you put a little 'anti-seize' on the threads for next time? :biggrin
SMOKDU
412
no i used this red lock-tite stuff :biggrin
Great choice! You da man! :thumbsup :lol
Lorenzo
626
U.S.A.
Thanks for the up-date. All to often we dont get the episodical end.
AJK
336
AJK
Anyone know?
SMOKDU
412
Anyone know?
Might just be caused by heat but i will know next time because i used the right torque specs this time. Either way it is out.
...............HERE IS YOU BEST OPTION, Your local Snap-on dealer has these on the truck,Get him to demo this tool for you. I have one and i promise you it will work and you will be pleased.
The 'Auto Fix-It Shows' (2 Guys Garage, Gearz, Truck U, etc....) have been demonstrating this tool recently. Quite ingenious!
standj
GT OWNER
755
Wyoming
Guys, I have one of these tools and they work GREAT!!! Used it yesterday to take off the rusty rear bumper bolts on a 2500 Chevy pickup. It is a must have for those in the RUST BELT.
John
steved57
1,941
kilgore tx
Lorenzo thanks for the tool info as I will be ordering one tomorrow
steved57
1,941
kilgore tx
Who has the magnetic drain plugs ?
Lorenzo
626
U.S.A.
www.gtsaver.com
His name is Jay.
Forum name is analogdesigner
analogdesigner
950
San Clemente, CA USA
I should have some left. Send me a note if interested.
Jay
(949) 412-8889, lv msg
www.gtsaver.com
His name is Jay.
'57:
If I remember correctly, Jay removes the "standard" magnets from a set of drain plugs and machines the 'plugs to accept magnets that are about TWICE as strong. (I had a set of these, but, sold 'em when I sold #1079.) The magnets in his 'plugs will darn near pull a unopened #10 can of peaches off your kitchen counter!
