Fubar's GT Build
I know, right? It's ridiculous when he starts talking about the MoTeC M150. I just nod my head and try to look thoughtful as he unfurls the details of the ECU strategy. hmmm, yes, right, I agree with you on that Shawn (waaaa?)
MAF sensor.... lol :)
I hate those things....
The MoTeC M150 will be using a MAP, BAP, AT, TP, and RPM sensors, along with a VE table to derive cylinder air mass. It will then use this air mass calculation and a target AF table to calculate a desired fuel mass that will then be converted to a fuel volume and then a duty cycle.... for every single cylinder cycle! :)
Cheers
Thanks, so "speed density" not MAF. I think the stock ECU can run Alpha N if the MAF fails.
MoTeC Magic
Spectator
Aug 21, 2009
99
Sort of, but it's a fair amount more complex than a basic speed density system seen in 99% of oe and aftermarket ECUs. Using measured sensor values vs calculated theoretical values based off things like known throttle mass flow... the ECU moves between measured and calculated fueling strategies... the monkey on the keyboard then can determine when and where either is used... typically for spots where engine resonances might affect things like pressure transducers, etc...
I'm not sure what to call it but it is a good step past typical speed density.
Yes... Defaulting to a "limp" throttle based fueling strategy is pretty normal... most OEs incorporate this.
Cheers
Fish put all of the bits and pieces together for PRI. The old girl rolled out onto the showroom floor this morning. It sure makes my right foot twitchy.
GTJack
1,729
Saddlebrooke, MO
Purdy!!! Put a red bow on it and light it up for Christmas!
Unfortunately the intercooler tank wasn't completely done (and it covered up a lot of the billet parts) so Fish choose not to leave it installed for the show. Here are a few shots with the tank in the correct position.
jcthorne
792
Stunning.
DakotaGT
1,715
Sioux Falls, South Dakota
Good God.
'VERY impressive, Mark. 'One HECK of a creation.
I wonder what the diff in the car's weight might end up being?
(Doubtless there will be enough extra h.p. to deal with that regardless!!!)
TO AWSUM
Ford GT Owner
1,512
Niceville FL
Wow. Love to see it in person. What kind of rwhp are you expecting?
Fuel type will play the biggest factor on power level. Hoping for 1000hp on 93; 1300 on E85 and north of that with a barrel of race fuel. It's all guesswork tho. If the system works as intended, it will come down to how much heat we scrub out of the boosted air.
mmlcobra
1,224
Wow,wow,wow!!!!!!!!!!!!
Can't wait for the dyno results.
The packaging part is just incredible.
Congrats.
Mark
Man oh man that is incredible Mark!
May want some new tread on those Bridgestones, hahaha.
Very Impressive, Mark !! - :thumbsup :thumbsup
MoTeC Magic
Spectator
Aug 21, 2009
99
Mark is correct... fuel will play a large part in the attainable power levels... as will engine options and fuel system options selected.
The new system will support 2000hp+ on Methanol, 1650hp+ on Ethanol, and 1190hp+ on 93 octane gasoline. That puts whp figures in the 1680, 1380, and 1000 ranges.
GT500s with stock intercoolers and 4.2L screws are already in the 1600-1800hp range at only 26-27 psi boost. We currently have two other GT500s in the shop in these power ranges. Mark's will be out in the 30-40psi range with the 4.5L Whipple with the bigger core and all of the cooling mods we've developed. We're also already working on a billet 4.5L with other upgrades to be revealed later.
Our entry goals for Mark's car was 1000whp pump and 1300whp E85. These were conservatively set goals and know the systems will be able to generate the above figures.
Cheers
Good question, I've never thought to weight the parts. It will be difficult to say what the different is because so many parts have changed over the course of the different builds. I guess we could weigh a stock GT and compare. The majority of parts are aluminum so it's relatively light. The bigger tank and resulting water capacity may be a bit on the heavy side.
I know right!?!? Thirty-Gazillion dollar motor and then some bald-ass rear tires, what the hell? = because race car
That's what I was thinking: that is, weigh both a stocker and your car (when completed).
It would be interesting to know what the diff actually turns out to be.
She got some attention at PRI. We had a lot of interest is writing up a full article once it's done. Magazines probably won't exist in 2099 but you never know.
5.0 Mustangs & Super Fords Magazine:
Then Mustang TV
**The article is not entirely accurate but it is funny. Hopefully we can get back to cranking on it after the holidays.
Marry Christmas my friends.
"The GT was nearing completion when Fischer showed it at PRI..." :party
