FGT Oil Pump Drive Belt
vyprgt2
609
CA
I purchased one of the eBay oil pump belts and installed it a few weeks ago, went smoothly- around $150
Thanks for suggesting the replacement and for sourcing the part number. Looks like a good idea.
Ron Resech
Jul 8, 2020
5
Do you have an oil pump belt 4G7Z-6B651-AA available?
Ron Resech
Jul 8, 2020
5
Looking for the oil pump belt??
978
There's some new old stock out there(10 years old). I haven't been here long but I haven't read about a belt failure. I have read about an oil pump pully failure. There's probably 3800 people that would like a new belt.
Somebody found a third party that has one that is a spec match, but I don't think anyone's been brave enough to try it yet....
Tipo874
Tucson, AZ
Grainger part Y-720
HighHP
484
Spokane, WA
This might be helpful. A post from last Dec so prices/supply have changed.
I purchased all new belts last summer. I had the same concern about buying new old stock belts. So I tried to source belts that are equivalent common use. Some luck. The oil belt is probably made by Continental-ContiTech and is available thru a variety of suppliers. Here are the results of my research:
4G7Z-6B651-AABelt, Oil Pump - Ford83.00
Y-720Belt, Oil Pump - Goodyear
45PL36Belt, Oil Pump - From Grainger46.00
20038721Belt, Oil Pump - Continental
Y-720 SIlentSyncBelt, Oil Pump - ContiTech36.00
4G7Z-8620-AABelt, Supercharger48.00
4G7Z-8620-BABelt, Main/Alternator29.00
Dayco 5100883Belt, Supercharger50.00
Dayco 5060923Belt, Main/Alternator32.00
I ended up buying all three from my local dealer who sourced them from Ford. I could not determine if the belts from other suppliers were for sure correct (probably were), but the prices were better from Ford, except the oil pump belt. The Y-720 SilentSync seems to be available from a variety of suppliers. I figured that I would rather take my chances with Ford. The oil belt did have a date on the package of 2010, remember this was sourced from Ford last summer. The other belts have recent dates on the package. I have attached pics of my old and new belts, the new ones are the brighter white print. Keep us posted on what you find.
GT101
*UK Support*
399
Colchester, Essex, UK
We've been fitting the Y-720 - Continental ContiTech SilentSync Belt for a while now - fits perfectly and works exactly as it should.
Reactions: PL510*Jeff
