This thread had caught my eye and was just perusing when I ran across this post about replacement bolts. The following is just food for thought when replacing any structural bolts that are loaded and unloaded. I did not work on the half shaft fastening on the GT...but higher grade bolts often don't mean better for an application for two reasons:
1- Hydrogen embrittlement potential. Ford actually stays away from some of the highest/hardest grade bolts due to brittle failures and difficulty of process control during manufacturing.
2- A proper bolted joint that sees cyclical loading has a joint (the material being fastened together) that is far stiffer than the bolt, so that the proper bolt actually stretches when torqued properly (not yield though) to create enough preload on the joint. The correct amount of bolt preload force is required so that as the joint is loaded and unloaded (including reverse load) it still maintains enough preload to keep the joint tight, no slippage and not allow the bolt to back out.
So a harder and stiffer bolt torqued to the same spec as the softer bolt has a higher chance of backing out because the joint is not preloaded enough. All new joint/fastener testing for a harder bolt is ideally required to find a new torque spec and it still may not perform as well as well as the softer bolt because of preload needs.
So the bolts chosen may work, but wanted you guys to beware that a higher grade often doesn't mean better.
Scott
I you want to read about this and more.
http://www.fastenal.com/content/documents/FastenalTechnicalReferenceGuide.pdf
