2005-06 Ford GT Build from Scratch Project
GTMD
957
Uhhhh...I am not worthy
steved57
1,941
kilgore tx
Wow just wow what an incredible endeavor
HighHP
471
Spokane, WA
Hey !!! Thanks for sharing. Very impressive work. Please continue to keep us all posted. :)
I too noticed that ol' Radio Shack Micronta power supply, I still have mine also. However, my variable power supply gets the use now.
SkeletonGT
48
Novi, Michigan
Wow! Nice to see someone going to the lengths needed to help us keep these cars on the road.
Got an even bigger kick out the Realistic? Radio Shack 12 volt converter! Use mine frequently for testing.
Jeff
I know it Jeff! I've had that power supply for 40 years and it just keeps working. I still have my TRS-80 Model III in the basement. Too bad Radio Shack couldn't figure a way to keep up with the times...
Reactions: bret a ewing
SkeletonGT
48
Novi, Michigan
Ok, I spent some time this weekend connecting my lights to a friends GT. The first pass went pretty good. The first thing I noticed was that the OEM taillight has the electrical connector so high, that its nearly impossible to get off without removing the taillight. Mine puts the electrical connector in a good position for connecting/disconnecting without having to remove the taillight. The second problem that I knew about, but forgot was that the OEM taillight uses those destructive nuts that cut into a plastic bayonet that serves as a thread. You can only do this so many times before it won't hold your taillight on anymore! Mine uses threaded studs which I think is an improvement. So here are the results.
y4mspXyThGbFSkNwcS0OYnFM6d786I7K8-pJ8xdc4muSp6VMcrh71hGPAG8_6_Y66GX_ougiR8c78e_L3mxJ3wn2U5TLADo1MCqE6ryt2O3Bo5ds4H3ByGLWMC53_jqY_KU62okKJLhg6AIIxZAotkTVn1wm5FYciG7vzUf1BpY8DkgOJrb_3NYsQn9hQseWMkX
Here is the car with the parking lights on. My taillight is on the right, OEM on the left. BTW I love the gulf orange color of this car!
Below is a picture with the brake lights on. The brightness seems to match pretty good. My levels are adjustable if I need to make a change, but I think I'm happy with them.
y4mEOFvD-1K_meBC0gMkAkNGijCCnc6_CHY6WYX1wiU04ywU6gwqXWAKOlADRQUjYUBPp5H0b1IfX-8BOmYkQX5feBJDNpsjOrAD2XgcM_bJGMYo8RVxSHMlGp4dGC63r45TO20gIGsCWBpAGB7ezCrDvDLhkQBgSX-96Cs3UGLrCQVJOAg2xeHa8whyDN6BkOQ
and finally the reverse lights. Note that these are LEDs, where the OEM uses an incandescent bulb. Its hard to tell from the picture, but the incandescent has a little yellow to it where the LED is more white in color. I'm not too concerned. after all these cars were not really designed to impress in reverse.
y4mr3QGJTOMzBnCJ_AquZki88P_2foBSpYx1QQJoh2k2So8N3lZxZp25sGBiiOnq7Y13eZCUBNjUTtp4bJISxvzPAWVBVwn_BItBOU6zVD_W_q-y89L4w24OOpyRjP5HFiTUuQnmGUl6mHVC5s0oahwFgkkzEx0w2QwkiA-rUFRpHKwiIRAsFFfSTB0wGY9EKdA
So I did find that when the right blinker was turned on, the light would blink faster due to a different load than the OEM. The flasher relay that you hear clicking is mechanical and the flash rate is based on resistance of the load. I found an electronic replacement for $12 that blinks at an electronically controlled rate no matter what taillight is installed and that will be my remedy. I had my first completely clear lens with me and for grins taped it up to see how well the GT dons the "Evo" look. I think it might look good with the right color car. I'm not sure I like it on with the orange. Did I say how much I like the gulf orange?
y4mt4U8sOPyQ80L-njotdY2EpcLiSbZzKXF4fnSQmoBToC6opEvBpWNyhaRo8C4Ik7lfjgihrLg2RvC3MSXvfkJmctNKaAI_160orpaUnpy_ZuyalTycqceJnsIo4GqGkkCjDLbbpWzzZl5A05dsrh9gqZ4IZa3ztEJQxZ3HNnuGPe4sp3YsS7JTh4Xa7JCASD0
The fit was pretty good, but I had a housing interference issue with the mounting flange that slightly tilted the assembly. I am going to reposition the rear cover and also recess it to resolve that issue. Here is a shot from the inside to see what I am talking about. Do you like those nice reusable studs?
y4m9jKybp9fOWZoZ2XnsRUdsAc2bIJfeE10mKlxXPsNe3Ywq_G90xoyuahDJQbUf3j0NXBuo9xiMNgsQPr06ivj_9CF33fQtt0scNg3x5V-LV2S2pAKKL_E1B94h_R2eKsiBUkCq8Sp9sYO-9GDPWRQXYqtQ25cJ5CLtgEkoXGQZoeECxifXgEznbdmwrdcdmTM
I'll continue to keep posting with the next developments. In the meantime I am really, really trying to pick up a wreck to help speed my project along. There are a few on copart that I am impatiently waiting for an auction date. If anyone knows someone with a wreck, I'd love to talk to them.
By chance is the Orange car the ex-Stillen FGT?
HighHP
471
Spokane, WA
Very nice.
948
What causes them to burn? Is there a common problem? Failed airbags on the other one?
As the OP is in MI and so is forum user "Jim", I bet thats Jim's normally aspirated bad ass car.
Reactions: 2112
Jim
205
Michigan
Guilty....
Reactions: 2112
SkeletonGT
48
Novi, Michigan
You are right, its Jim's and it is Bad ass.
SkeletonGT
48
Novi, Michigan
Sorry GT@50, burn? Do you mean the fried one on Copart?
948
2 fried one's on Copart. I've seen a few others and there's a halon kit available for these cars.
I completely agree, its awesome. When the frames were being sold, I had dreams of making a NA GT, then woke up.
SkeletonGT
48
Novi, Michigan
Hey guys, many of you may think that I gave up or sold the project, but I did not! I'm making great progress and I hope to have the car running by the end of the year. I spent more time working on the project than sitting at the computer updating my progress, but I feel that I left a lot of you hanging, so here goes. I will try to do a cliff notes version in this "catch up" post. So I've been collecting a lot of parts, made a road trip...
y4mBfXs0KNyuPV5CjAPeu6_jB97k8RSc9MUulO27m6z-ZvWSirECkBxwkif1Ig46VrSiYR73k55cN4RcDTldn6NZg5jk5zaPKqJ9N6cVlKubsOkFMEbTUQPKycLaPISoav2_Yz9VNyyuHSOCDiz1rWl_00Il-lKyxRFSjVwDm-qi4L3PO0Bbh-QJvUyMpsW3W7T
y4m1uio9RJ712wziNO28AJMuTvLnqqTZFKChIHOMV482xIWn7Bn6MmHSnbniV-RBucNt3N_NoUP_yf0YMN21YaUwnA0cWIMy6cWJ7IrcHeVnZ1-tF19OBQfdYdw_d2tYSUOk9QgoQGfxl9eiKYv4jd11vsXULs0jtoppXLdQPHWE6lzFpMaFexijf2NGiXw410_
And I've been making a lot more parts... Cooling tube bushings, Gas Pedal, Degass tanks, widebody control arms, gas tank filler mechanism
y4mR5i1Zs-T-nO7YZSxnSxT0ZEvsUQUGiiyrXn4oSORd2qC2o4m7IkSuz74qxyPqVBqm4aruXAB5sllH_9wxH94zeALkBDdQt52aB3-qTwBIY61IhS6IFVavhh7t9W4zD3cKQZ4vdvPCSSkxwH41_e7ADvoQN9EVrsr0dd4O7KiqUlBxklssP2gaHkoZT0tZy89
y4mX8hPYNH3tO1-k0phfdDP1XZqJE-cLucG2c4rcn01myGnr_mZ37UBTveFO2YCiha_Lmvuejxbl0rvRUChVM25WjInTaa-etBy0bFTHSbP5dMA_4dAmlHuRyGWXZU5VzAgjc-HC2lWnGlo3XS6D6Z-LHEGYOokI24LIPW_MyNg1ucxZHFX-sKNQZP_BlKDJ0gS
y4mobC5XVLdiIUnrQihCMUALOiAjBpz1w9RRO7C35UuYIAnHyHuO8Ko9VVTVYQoxxvtZJQ_3iK66wbVC_vj-bD_uph5ETZVLqQMYpVANtxbFTaykf70cczH5A31zb7fxK1k8ccx4rdWk38d8GxEUH6oLKNpO8YuL4JmSh2r371pSJ9iIwfbKZngc_S6XhCosde0
y4m34_6_T9RUAlB8AMQb85L_DS1yyjaHHx2Nk3sZwvaB9n62JrN0_y5GBbbkBRgTTMIv-V0xoEiT7fhunDS7SuJUq5WYw5ysuw2f3oTI0KG0s3QTI-rshj9RsIN8n0hXEuIVkEuYRiRcR1sY2tRIYvC1_n_H4yMaqsJpXuBlcp2OV61dlfGknMM5ojx-g5vKP3b
y4mORnJ9Su9QcSGIyaQWe9zp2fhHHBLIlJW5EFXPl3Yc76ir7mILe9IZo2isvR7ER-Bjr_vRQWYFW_AiOKT21wDNXgEmvB4oCveiMTFjM4SPkzdDJIIvODcopbAjFKcit1A_-5hDun6Nx1AnL8wFWmS6rQ1V2gl0wuhAyZfgm-g93ZfalQ5DzdIm_RujPlLyOSb
Where is the car today?
Complete interior wiring harness, IP pedals, HVAC, seat belts, brake booster are in. All the tube bundles are in and the bottom of the car is buttoned up.
y4mk6KQxzFsmXyg4vFwZathCNHggBHpkM3k1P5EfB6rEo_0WtPTs7j-ByrtZdI_Y-Zx1ucLdj6qjW5S4qH6hK9iSxNpzfR7dChHmxokOoaFPvKUQ5dEsInCdDgyJsYYdtCGUjO2PVkVf6pUqxzLmvusXs2y8ojnkCfONwZ4C_ae4Jtuoi5hPTXT_ZxOpWNY-msH
y4mq6cnaRhwJAO7QTlYhf0kCvxG-qZYTOZA5NhJRK4CUj90WlZdHSQzX6Dm2vmPpAYoBiEWNTamdK4V4GnD20ZLjngFtJhRKWD_XA4ykf35mU4pDzq2iKQNPl0BOLQqx_IvRnF8HROFTQxXKyWOSzvmAbivSfy-Q1WPM7v36uc8pQ0pneHobEFKLQu9Meefq35h
y4mnxFA039QHJXo7ZGokiCKg6RPQ2HxznaTeS4HWTYI10Ed7IJqEC415K9N9stubqQLcNKAxKhDKhGS8QskVW1s3RbnmefivX8LQlmqakLte9ISbIcyDTCLtai7LjPzU7_fYoXv-Bgw5AUINJFONMuCgmDTlWRcq4nnOe4B9Cd_FrN57Fzt3PGD8yxEmjvnA1x6
y4mA-n_JIAOPahGcuHbsJ-OsfZvmPDY80xf7BR-y0sEfWahLdSr_GR9OvJ-tdZFNBkYd_pz1d8dUGMRetV3grXxC3a_Gx_Ft7KiEFdIO1Jl9oH1GsoT5PlMTauiw0osqaxnzDUEWt2vKo3-h2bcqiSj0ekUbLIBxqVvEwGHkmekMTfcJ14hxAcawogRqK-G9QN2
y4mpatKkdGS8m6iPB0zsf-TIrvdVviiJzgSblNqSYPzj2Kw8HMcR_FB5OHCD6_W2nHsFSjdFMagcd8SK5bLCUM-ejUfIQsBaBJx238QPV559-m9-xrevDPmXUq9Agm7iksD6FXryOR0FRMizsHhwVG9Uf5gHeOJNlk0Eg-eaKjwaA3EYdMsh9zr9zlBMLY6rF2q
Also found some pretty cool GTX1 rotors and calipers. These are 6 piston and larger diameter than stock. I had never heard of the GTX1 car until someone came out of the woodwork. He also had some coilovers from the GTX1 car.
y4m1J0obFoGv6NTkcwERxx75YXGWHcHEuWnMiktqcSlB4GBGzHQqwBZr2Y1OWWK53FJPdRXpIVZPB1r6cgPfi3m_90BM6PBAecAWrkjajp_Ov-Pe1XG6I1si1GSsu5UU7h34uZLQLXF3LXVyx6ubeVbWZTCJgyQ5hvytwZZ9tZISY0ZkQoECFo1sbTI-8M4fqD8
y4me5hKmkrn27umXkxRkGoXVJPohspbYOMgDjNpyioToSh2A206tSdSHFYTAqZWgYcyn3FAs7jyLwVDdj7vlBFiJQAIMhSCKugaJ-RyeGzqTi8gCnZOVzUtU2PyjgPBiLYy4FRxCgdU7sM25a67y5QNTwXUCH2dt4BpHGhoeVDOYbZDrFp_qSAKWWQdTe9JfXO-
Next steps?
The bushings are still alive!
y4mIxE5jzbGRoz3D6gg6JAeAPdFvzt-yHPi-KyDarmcxwDLdeeFYUZrXOJKJggYQ5wXzNcfPVyh6AKUJTcJgLmYWNbmb_UHj_3D9M5XN5SDLhDo4AmdzP6m17vSrlXIA9nQCEqRLU7f_TKVHkNsIxkUk-XEpLXv-1oQXYoc0wVSjjZDG6wYdtRZX5N9diSfxGHs
They will be pressed into the new widebody control arms and mounted, the rest of the cooling system will be connected, the front wiring harness that I have is a mess and I will have to splice and dice to get it done right. A few more connections like AC, power steering, brake lines will be needed, but once the cooling system and front electrical is done, I will actually be able to try and start the car, which will definitely be happening this year. The doors and widebody bodywork will come later.
If anyone has some parts lying around, I am looking for a drivers door and a passenger mirror!
Sorry for going dark for a while, but I will make a point to keep this updated more often!
#IMPOSSIBLEGT
HighHP
471
Spokane, WA
Appreciate the update, keep 'em coming. Like the TIG work, nice stack of dimes.
A labor of love. Will you keep it RED?
SkeletonGT
48
Novi, Michigan
I've been struggling with the color. I want it to pop. I like orange or a brighter blue but red is safe and always looks good. I want it to be unique.
KJD
1,020
Location, Location
No need to be safe with this project, paint this beast so it will glow in the dark!
STRONG WORK, thanks for your creative energy and updates!
