Whipples, Pulleys, Tunes
the 4.0 L will run cooler too :thumbsup
Maybe
Fast Freddy
GPS'D 225 MPH
2,737
Avondale, Arizona
why only 15 psi?
it will run cooler :thumbsup
if you race your car in hot weather on a short track road course less psi will make more power as your motor will pull timing if it gets detonation, so lower PSI is not always a bad thing in the case of road racing.
when it comes to drag racing and 1 mile top speed shootouts you want max PSI......
Hi Shadowman.
Thanks.
Sounds like 19lbs is the number ...... looks like I need a new boost dial. hmmm
SM..... You got any dyno's of stock V's Whipple.
I'd love to see how the Whipple makes ass shoving power from 2,000 onwards.
The majority of the time the engine spends is in the range of between 2,000 - 4,500rpm, that's what I'll drive in.
I will only sneak past that when the time is right.
Apples
Apples
The supercharged gals shine in normal driving and when one wants to exercise them they will pull like a freight train from 2500 to 6000 and after this still build power however once in this arena is where the TT shines as it got it's breath around 4-4300 and by 6k she is just finiding her sweet spot.
Now in response to your other comments; yes a new boost gauge would be part of the package and 19 psi is the direction I would encourage and lastly as for dyno sheets yes I have several within the files.
All the best
Oh and a awesome tune from Shadowman!! Thanks Shadowman you rock:cheers
Thank you for the kind words; it was my pleasure to be included as a member of your project team.
All the best
While the GT has no means to detect detonation directly, the ECU does carefully monitor Inlet Air Temps (IAT) and water temps and will aggressively retard timing in a self-preservation mode :biggrin
There are "NO" knock sensors and the PCM will "NOT" pull/remove timing based on detonation; the most significant reason that timing will be pulled/removed is based on the discharge air temperature and when it is above 150 degrees in OEM trim the process begins and can be extreme; so much that the gal will in fact nose over almost as if the key was turned off.
As nota4re shared; there are several sensors that can affect timing however non of them will protect a gal that is detonating
...when it is above 150 degrees....
242°
I think he ment that the ECU begins to retard timing at 150 degrees... at 242 the engine basically goes into limp mode.
Would someone mind posting their dyno charts from stock to whipple to turbo?
thanks
MM
tmcphail
GT Owner/Vendor
4,111
St Augustine, Florida
Comparison graph on my car Pulley & tune only (stock 2.3L) against pump gas TT
somelee
409
New York & SoCal
A good average on a conservative well balanced street tune is 735 rwhp
I have a GEN 1 Whipple with a 19lb pulley and "Tony's" tune. I finally got a chance to dyno the car a few weeks ago and was surprised to "only" have 661rwhp 603 ftlbs... this was at an elevation of 2600ft. Is this typical? Unfortunately the A/F meter wasn't working so I don't have that to read...this was on a dynojet.
Correct
Shelby#18
GTX1 Owner/Moderator
1,623
Nev./So. Cal./Minn.
I've been in that mode WAY to many times at the track! :frown
Yesir, it is definitely a 'limp' mode kind of feeling. :ack
