For those that have upgraded to the Whipple 3.0, please post if you get a belt squeak at cold start. My suspicions is that these belts originally come with 12 grooves and they get cut to accommodate our pulleys that only have 10 grooves. The side that gets cut, is not perfect and is causing the squeak/ticking noise that eventually goes away when the engine warms up.
If you do get the squeak, just add a couple of drops on the pulley and the noise will go away.
You experience and/or opinions would be greatly appreciated.:cheers
