Wwabbit
Do you think either the original shipment or the transferral involved ferrying it up the inland passage from Seattle or Vancouver to Anchorage, or do you think it went on land by the AlCan highway?
Hope for the ferry boat.
Ralphie, I will see what I can find out.Indy, Tomy -
Any idea how mine might have been delivered - I've always wondered? It was originally consigned to Nye Frontier Ford in Wasilla, Alaska, according to the sticker. From there, they sent the car to San Diego. Flatrod can verify that the car was in Alaska, as there is a story behind the movement to San Diego.
However, I've always wondered how it made those two trips....
Thanks guys!
Trailex was willing to install e-track, but the guy suggested I give the standard ratchet straps through the wheels to D-rings in the floor a try first. So that is what I am going to do. The straps will be well insulated from the wheels with padding. I know a lot of guys do it that way without issue.
...if there was a car transfer to another dealership in San Diego, I would think Ford distribution was out of the loop and the two dealers would work out how to get the car from one dealer to another. Did you ever ask the dealer in Alaska how the car got down to San Diego?....
Do we think that a car secured by straps that is left in gear that may move slightly fore and aft when start and stopping is going to place anything remotely close to the load on a gear that 600hp sitting right in front of the taxle will? Are the cars you see on the backs of car haulers heading to dealers shipped in neutral with no e brake?
WOW!
Dr. Frank weighing in on a technical post.....? (and logical at that)
Extraordinary, and no argument Frankie.
Really? What about when your car is in a forward gear at rpm and you let off the gas? Much more force than simply pulling against the engine with slight shift fore and aft during stop/start in an trailer which isn't going to start/stop very hard to begin with. I think you guys are going full anal on this topic but it's a free country lol.Luke,
When a car is trailered in gear, the drivetrain is exposed to forces not experienced during normal driving. For example, if the car is left in a forward gear and the car is pulled rearward either when strapping the car down or by movement during trailering, there is a strain on the gearbox which is not present when driving. Also consider that the manufacturers strap the car down one time during delivery, whereas owners may trailer their cars many thousands of miles over a period of years.
Paul
Ice, I agree. I believe the issue here is “dither” or slight movement back and forth while the drivetrain is mechanically coupled to the rear wheels.I would think it has more to do with the same contact points on the gears and bearings moving back and forth without the benefit of getting new lubrication from the shafts moving and in some cases like the FGT the oil pump turning.
Certainly makes sense to me to follow Ford’s recommended (and most likely tested) procedures. Can any of our owners stand up and say they know more about our car than the Ford design team? If that rises to the level of being considered “full anal” then so be it…..See page 10.
