Trailer for 2017 FGT
OK. I agree. Tacos in the shade are better than Tacos in the sun :)
And added the PITA factor of also having to unload with the winch and making sure the trailer is tilted back
Obviously you've never done it - whereas I'd say I have 200+ load/un-loads of GTs into a trailer + countless other cars. You made another point in favor of pulling the car in - it can easily be done solo. Go as slow/fast as you want. Stop to make an steering/centering adjustments as needed. No tricky clutch work. No need for a spotter. Unloading is equally trivial. The car is still tethered to the winch (although I add slack during the actual tow) but you just park on level to slightly uphill ground. No problem. As in loading - no spotter is necessary. No climbing into the car. Stand in front of it (excellent viewing position) and, if need be, use shins to give it slight push. Simple.
Fine for me for folks who see no need to change/improve the way they do things. Maybe the cost of a rope winch with remote is too steep for a $250-$500K car. Ignorance is bliss.
Ignorance is bliss.
You must be ecstatic.
Biginch Blake
993
Rockville, Indiana
I have three 28' trailers all V nose. One retired to loaner, someone is always needing a trailer, because of no side door and 60,000 plus miles. The other two both have side doors and thousands of miles. Had the single car trailer special built with ram over for wheel wells, Harley fits in front of car. The other is a stacker 3 axel and top car goes in above wheel so I think I am set up. Never had any stability problems with the V nose. Had to pull a friends flat nose and it cost me 2 to 3 mpg. To each his own but the V nose is free storage for track gear. Just keep your bearings serviced, tip of the day.
I winch on / drive off. No winch on / winch off. Sounds like a Karate Kid technique.:biggrin
But seriously it seems we all have our own process, there's no right or wrong way. Whatever you feel most comfortable with.
I will say winching the car on is the most favorable situation for the clutch longevity.
Side doors are great. I wouldn't buy a trailer without one. I guess everyone who builds one with the side doors are building weak junk...:lol..
Play nice boys remember what you learned in school... if you don't have anything nice to say don't say anything at all...:biggrin
I don't have a car trailer nor plan on buying one but this was an entertaining thread to read.
BAT
946
Central Mitten
TT / Supercharged Wars > Tire Wars > Trailer Wars. :lol
Spirit
Heritage GT Owner
Brian, you forgot the 9mm vs 45 cal Wars. :biggrin
Just Drive 'Em. :cheers
BAT
946
Central Mitten
9mm all the way.
Spirit
Heritage GT Owner
9mm all the way.
:thumbsup
cobra498
310
Central Ca;ifornia
9mm = Girls gun
Fully agree, Brian. Many of us owners have fine-tuned their processes and they work for them - no worries.
For newbies to the trailering process there are choices to be made. Width of the trailer is likely now one of the paramount requirements! Certainly anyone can be a trailer with no side door and no winch and choose to drive it in, shimmy out the window and then do the inverse to get it out of the trailer. That process will work time and time again - and there are likely many people that do it that way - quite successfully.
The next level of convenience would be the addition of a large side-door on the trailer that permitted the GT door to be opened for far easier ingress/egress. You could still use the same drive-in/drive out process - but it is alt least easier to get in and out of car. Again, a lot of owners doing this very successfully. No problem.
IMO, the NEXT step of convenience is the ability to winch in/out. If you are setting up a trailer for this, I would recommend a rope vs cable winch and with a handheld remote control. Drive the GT to the foot of the ramp, and connect the rope, add tension. Remove parking brake. Use handheld remote to pull car in. Stop as often as needed. Stand wherever you want to have the best visibility. Move around. Make a steering adjustment if necessary. (Remember you will likely only have an inch or two of tolerance between wheel wells.) With the car in position, strap it in. Add some slack to the winch rope/cable for towing. Almost identical steps to un-load. Note that un-load is likely a far easier step.... often just requiring to hold the steering wheel straight!
The bottom line is if trailer shopping, let's assume the following (generalization);
1. Least expensive & most common: Trailer with no side door and no winch set-up but sufficient width for GT
2. More expensive: Trailer above with winch & remote capability
3. Most expensive: Trailer with large side door (but no winch)
4. Best of all worlds: Trailer with large side door and winch set-up
To summarize my opinion having direct experience with all of the above.... I would recommend 2) over 3) above if I was recommending a trailer from scratch and 4) if I had the budget.
...Star Wars. ..:lol
You should get one with the side door... I'm planning to sell tacos at the next rally... you can park next to me and serve up some cervesa...:lol...
usually it is less expensive if you just drive it to wherever you're going. no trailer required.
Sounds good to me. Will Dr Frank be selling the beer?
TTS
31
Hastings, Nebraska
Anyone tried the Rail Ryder system?
I'm sorry, but I am contracted to Magic to have a perogi truck out of his trailer. We do not have liquor license.
I'll be selling curry and Indian snacks out of my trailer.
I looked at that trolley system. It's neat, but I thought that aligning the car might be difficult since adjustments aren't possible as the car is entering the trailer. Also, it makes using the trailer for other purposes more difficult.
