Richard
Do you have the Part #'s for the shims?
Are these also the same shims that are used to adjust the bump steer on the tie rod ends?
Thanks...good work, my dealer could not find them listed any where.
Front and rear alignment shim information:
Type__Color__Act. Sz___(Ford)_______Part Number____List Price__Hole Size
Front__Black__4.0mm__(NOT 2.0mm)__4G7Z-3A182-AA__$9.67 List__Large-L
Front__Blue___5.0mm__(NOT 3.0mm)__4G7Z-3A182-BA__$9.67 List__Large-L
Front__Red___6.0mm__(NOT 4.0mm)__4G7Z-3A182-CA__$9.67 List__Large-L
Rear___Black__4.0mm___-----------__4G7Z-5A802-AA__$9.23 List__Small-U
Rear___Blue___5.0mm___-----------__4G7Z-5A802-BA__$9.23 List__Small-U
Rear___Red___6.0mm___-----------__4G7Z-5A802-CA__$9.23 List__Small-U
Hole Size: L= Lower control arm; U=Upper control arm
Bump steer shims? At this time I do not know. Check Part number for the bump shims against the above. I'll also look into it if you'd like.
