stock clutch versus aftermarket...
Can Spec clutches still be special ordered? Or are they done forever?
They're still listed on their website... SPEC Clutches for GT
Reactions: Fast Freddy
Fast Freddy
GPS'D 225 MPH
2,727
Avondale, Arizona
It used to be when the trans warmed after driving that i could get into first gear without it sticking, but not anymore as it sticks even when warmed up now. So i found a new stock clutch on ebay and ordered it on wednesday. I got a tracking number. I always thought towing in gear bent a shift fork. But according to the GT guys who installed my B&M shifter Rich Brooks says i have a stretched cable. Ordering cables next. If this does not solve the problem then either i get my tansaxle fixed or i will be buying a new transaxle. As far as my clutch wearing out the burnt clutch smell is a result of too many drag launches. It still works but the days are numbered.
Fast Freddy
GPS'D 225 MPH
2,727
Avondale, Arizona
Just ordered new shifter cables from my preferred ford dealership and the ford GT tech will be installing them at the end of this month. Gonna flush the clutch fluid too and wait to put the new clutch in i just bought until a later time as i think i can get another 5,000 to 10,000 miles out of the original clutch as long as i do no more drag launches. If this does not solve the problem then i have an issue with the transaxle...
Art138
632
Weston,FL
Did the clutch come with the pressure plate? If not, why wouldn’t you change that part also?
Do you have the part # for the cables?
How about the clutch assembly?
Fast Freddy
GPS'D 225 MPH
2,727
Avondale, Arizona
The only way you can buy a stock clutch is with the pressure plate. They come together and are sold as one unit from Ford. Torrie McPhail from Unleashed Tuning on this site has 2 used ones for sale that have less than 1,000 miles on them. He even has pix...
Fast Freddy
GPS'D 225 MPH
2,727
Avondale, Arizona
2112 - call your dealer for part #'s. I had to supply my vin # and mileage for them to order any parts...
I am asking for the part #’s
Art138
632
Weston,FL
Here is the part number….
Thanks Art, do you have the cable Part # too?
Bbhaynes
62
Madison, MS
I have heard good things about the RPS Carbon clutches. That is what I’m about to put in my car. Suppose to drive like stock and hold the power easily when car is modded.
Reactions: TORQJNKY
949
Bleed the clutch before you do anything else. If clutch isn't releasing fully, it'll be harder to shift, more so with a new clutch. There isn't much fluid in that system and half of it is mounted in the bell housing surrounded by exhaust. It gets cooked. When trans is in gear the cables and forks do nothing. They're just sitting there relaxed until you shift. I've seen excessive fork wear in various trannys (can I say that?) from resting your hand on the shifter causing a constant load on the fork and fork wear. This leads to not fully engaging gears and popping out of gear, not hard shift.
Fast Freddy
GPS'D 225 MPH
2,727
Avondale, Arizona
I am the original owner of the car. the clutch fluid has been replaced twice. Arizona heat, racing in three states and Borla headers... i bet my shifter cables have melted. New clutch fluid will be put in too 🏁
Reactions: GT@50
Do they have an application for the GT? (Not listed on their website.)
Art138
632
Weston,FL
Are these the cables you are looking for?
Reactions: 2112
Bbhaynes
62
Madison, MS
Yes they do. Nth Moto is doing mine. It’s pretty much custom made to order though. Here is a pic.
Reactions: 2112
Fast Freddy
GPS'D 225 MPH
2,727
Avondale, Arizona
RE: cables....a Loong time ago I had shifting issues. Ended up that the jacketing had melted inside the V of the motor. we ordered a nw cable set. I got a call from Ford from the man that put the cables together. He said never try and adjust them. I make sure they are perfect before we ship them. Never had an issue since then.
How many hours did it take to replace the shifter cables?
Thank you Art, will use those and ask for confirmation
Nice! Price?
