Stock Air Filter
Reducing any restriction in front of the supercharger (high VE or not) will absolutely increase the mass-air flow rate. Try thinking about it this way; consider the extreme case wherein you completely block off the inlet and ask what your mass-air flow rate will be. Basically zero, of course.
At WOT the mass-air flow rate of a positive-displacement pump is the product of its volumetric-flow rate times the air density at its inlet. Put a restriction in front of it and the inlet pressure goes down. When the inlet pressure goes down, so does the air density at the SC inlet, and therefore, so does the mass-air flow rate even though the volumetric-flow rate into the SC doesn’t change. And as we all know, a lower mass-air (and fuel) flow rate translates to a lower amount of (indicated) power.
I don’t own a GT, but this I can tell you. I took out the stock filter and snorkel in my ’03 Cobra, (which also has a positive-displacement SC), and put in a drop-in K&N filter and gained ~10 rwHP. At a later date, I put a smaller pulley on and did a baseline. I then took out the drop-in filter, MAF screen, and stock air “box” and replaced it with K&N FIPK and picked up 23 rwHP over the baseline pulley run as measured on a Mustang Dyno. (Of course that doesn’t necessarily mean you guys would see that kind of gain. It would depend on how restrictive the stock system is, which I’m sure is better than the one on my car. Easy to check though…take the air filters out just for a quick test and see what you get.) Does it let more dirt in than the paper element? I’m sure it does. Enough to cause any damage? Couldn’t tell you, (but I’ve had it on the car for about 3 years now). One could always have their oil analyzed to see what’s getting in and how big the particulates are. Operating environment matters, of course.
Installed the K&N filters and made dyno runs before and after. Not a single hp increase :frown
just bought the K&N filters and installed them as well, not going to redyno but I am not expecting anything more then psychological HP out of them.
Then the GT stock filters aren't a restriction! Good info, (although sorry to hear it didn't help any after spending all the time and money. On my car the stock intake was really corked up!)
The stock filters are fine. Also forgot in my last post to mention that John at Accufab says he flow benched the stock and K&N's and found no difference.
K&n
I put the K&N's in mine and ran for 2000 miles and noticed no performance gain. I put the stock paper filters back in since I do not trust myself to clean and re oil the K&N
So glad I read this thread. Changed my air filters today. Removing the box certainly made things so much easier. I can tell it has been a while since the old filters were changed if ever. They may have been the stock filters.
How many miles on the stock filters?
6600
ummm.. I've changed my filters 4 or 5 times.. How in the heck did you change them with out removing the air box ?? :confused:confused..
All the screws are on the bottom side...
No way to change them without removing the box. I had all of the front and side screws off before I removed the box.
Guys,
Here's an issue I just suffered with K&N filters. I changed out the OE filters with K&Ns and reinstalled my airbox in the car per the manual. Then, I heard a few loud 'pops'. I pulled the airbox, and the the lid cracked around the molded-in threaded bosses. I pulled the K&Ns and they are taller, and a little harder in Shore. That created the stress on the heat-soaked lid (5,700 miles) and popped it. A new assembly (only way to get a new lid) cost me $600. A polite letter to K&N got me a polite 'Buzz Off' reply. STAY AWAY from these, and stick to OE.
Guys,
Your experience prompted me to check my air box ( K&Ns installed) , and indeed I found one lug broken. My guess is that the added height of the K&N Filters is beyond the elastic range of the lugs to pull down and seal the two halves of the air box when screwed down tightly (?).
Consequently , it breaks off the lug. I've attached ( hopefully) some pictures of the height difference between the K&N and stock filters ( as best as I can measure it's about 1/8"), and the broken lug. I was able to re-attract the broken lug with some "Plastic Fusion" Hi-Strength adhesive, and it seems to be holding ( see picture).
Thanks for sharing your experience and observations.
My Fix to Problem
Without getting caught up in the controversy over the use of K&N Air Filters on the FGT , I'll provide my fix to the problem (if you choose to use K&Ns). I found that simple rubber faucet bibb washers ( 1/4 Flat, 9/16" OD, .15"thick) will take up the gap created by the difference in the heights of the K&N and stock air filter elements when installed between the upper/lower halves of the airbox cover ( see attached picture). This should prevent the cracking of the screw lugs and airbox cause by tightening down on the screws beyond the elastic range of the lugs and airbox .Using weather strip adhesive, I bonded the washers to the screw lugs on the lower half of the airbox . Don't have to bonded them since the washers are retained by the screws , but didn't want any small loose objects that could possibly get ingested into the airbox during installation. The weather strip adhesive stays somewhat tacky so you can easily peel the washers off if you want to remove them later. After assembly I stuck my hands into the cold air intakes and throttle body air ducts and tried verify the seal between the K&N filters and the halves of the air box cover by seeing if their was any relative movement. I could not sense any movement and concluded the filters were adequately clamped down to seal the filters within the airbox.
Can't say it will work for everyone ,but seems to work just fine for me ( but only time will tell).
Does anyone know if the stock air filter are the cheap paper type? Or, did Ford use a better quality filter in the GT? I'm thinking of getting the two K & N filters as replacements. Any thoughts? Should I expect any performance gains?
The stock air filter element - FA-1682 is the same part as used on the 99-04 Lightning. Because of this parts bin usage it is one of the few bargain GT parts - $19.95 each.
