Mine have been coated. Still had a problem!
Do you mean they still corroded?
I was refering to the fact that my FRRP cat delete pipes were coated and they still got hot enough to cause wiring issues with my starter.
Just to add to this thread, I had starting problems today. I went to Jonesboro to pick up my Heritage GT that Shelby has been keeping for me. Beautiful day for a drive through Arkansas. Left his shop around 11:00 and figure it reached 102-105 F during my drive. Arrived in Hot Springs after a three hour drive with some "spirited" driving spots, but the most part within the posted speed limit. About 10 mins. from my destination I noticed my check engine light had come on. Car was acting normal so continued on to Hot Springs. Once I pulled in I turned the car off and in short time frame tried to start it. No Go! No Start!
Pushed the car into my inlaws garage and started checking things that I could think of. Went through my list very quickly. Finally called Eric at Shelby's to see if he knew what to look for. Got his suggestions and went down his list. Nothing was coming up as a possibility. Called Eric back and since I have switched my exhaust out to a FRRP Borla Muffler and FRRP cat delete pipes he suggested I check the wiring condition of the starter wires. So back out to the car, look on the passenger side near the back of the transmission and what do I see, but a melted plastic connection that I assume is the wire going to the starter.
Plans were to drive the car back to Houston tomorrow, but instead it looks like it will be headed in a trailer back to Shelby's for a repair and additional heat wrap around the starter and wires. Since Ralphie has had this problem and now I, seems like if you have altered your exhaust system you should check out the starter wires and make plans to protect them from what appears to be excessive heat.
Big Thanks to Eric at Elite Autos for his help over the phone and continued service excellence.
Magic
Same thing happened to me this summer. It was the battery ground despite (because of?) my cleaning of the frame connection three years earlier. While I was down there I added a redundant ground cable nearby.
Howard
I was lucky enough to have Shelby vacationing in the area so he stopped by my inlaw's house to see if he could help get the car started before going to the trouble of having the car towed to his shop. Didn't take long to confirm what Eric thought was my problem that my starter was not getting any current. We unhooked the air box on the passenger side and moved it over slightly so that someone could reach down and feel the starter connection from reach into the area from above. Found that the starter plug connection had melted and was not connected to the starter hence my problem. Luckly we were able to get the connector back into the starter and the car started. No idea how long it would stay connected since it was melted. Shelby said he would drive my car back to Jonesboro right then and take care of fixing the connector and adding a heat shield to the starter. So Shelby's wife in their car and he in my GT set off for a 3 hour drive back to Elite Autos. We did discuss have the car towed back to his shop and he had someone lined up that afternoon to come and get it, but when he saw how steep my inlaw's driveway was he said he'd better just get in it and go as we might not be able to get it up the hill and into a trailer. Hopefully It will be arriving in Houston this week. Looked forward in driving it back from Arkansas this last weekend, but will probably just settle on having it trailered back.
My view is if you have done anything to the existing exhaust system where you have changed anything to do with the existing cat setup you should check or be aware of potential heat problems to the electrical connector to the starter.
Thanks to Shelby, Eric and Elite Autos for all they did for my car. Talk about service after the fact!
The GT must have a good ground to the battery which needs to be checked often as our cars are 6 & 7 years old.
Good advice where GTs are concerned, Tomy.
But, my DD (truck) is eleven years old...'has 40-some-odd-thousand miles on it now...'have changed the battery once & have never touched the battery terminals other than that ('have never cleaned the neg-to-frame connection). 'Truck starts each time, every time, all the time. 'Always has. The same general thing can be said of every other vehicle I've ever owned whether foreign or domestic, econo box or 'luxury liner'. 'Never had even ONE gauge fail on any of them either - ever.
That's why I can NOT understand why the FGT seems to be the only car in the world with constant ground problems/gauge failures (at least to my knowledge). I'm well aware of all the theories regarding same, but the fact remains the FGT is the lone resident on an alien planet where this stuff is concerned.
There has to be something that's totally unique to the design of the FGT's electrical circuitry/gauge circuitry design, or some component(s) therein (or both) that is/are the root cause. Toss it/them and replace them with the standard items that all other cars use and the problem should evaporate. (Regarding the battery thing: It should be noted that millions of cars use gel cells and none of them have caught the same ground/gauge 'plague'.)
I'll shuddup now...
Pockets the Profound
2nd - FGT does not have constant ground problems...
Agree with Mad. If your truck were all aluminum, you might have an occasional issue.
NSX's are all aluminum and don't have this problem, or any other really......
