Shadowman's OEM/NASCAR Style Front Brake Ducts
HA! "The next person" considering this project WILL SIMPLY BRING HIS CAR TO YOU if he has any sense at all, Bill! :cheers
That is an understatement of the year!
Anyone thinking of doing this kinds of modifications outside of DA is about as smart as those that work during the day at
East Capitol Street,
NE and 1st Street
NE Washington, DC 20002
:lol
BTW, the duct work is phenomenal! It's as an OEM would have done it in the absents of any cost constraints! :thumbsup
UPDATE
Here are a few more pictures
All of the fabrication work, dry-fitting, and then paint and powder coating has been completed as such the final assembly of the custom front brake air duct system is being tended to on both of the gals.
The first pictures shows the custom aluminum rotor backing plate installed after they were powder coated semi gloss black
The second picture shows the machined aluminum standoffs located between the steering knuckle and the rotor backing plate to insure proper support for the rotor backing plate.
The third and forth pictures show the front brakes fully assembled with the custom rotor backing plate in position leaving only the final piece of the flexible air duct tube to be put in place.
The fifth picture is the primary air duct ready to be integrated into the OEM front fascia on the second gal
The sixth and seventh pictures show the primary air duct integrated; in the case of these gals machined aluminum inserts were created to which the closure panels can be attached
The eighth and ninth pictures show the nose of the gal with the custom air duct system fully integrated along with the closure panels in place.
Continued.....
The closure panels were created for these gals so as to offer system flexibility, example, during adverse conditions such as heavy rain as well as extreme cold when having extra air flow and or water fed across the rotors is not a benefit they can be left closed. Then when participating in events such the standing mile using the closure panels will make the nose of the gal slipperier without the need for "blue" or 100MPH duct tape to seal the pockets. The manner in when they were integrated causes no air flow restriction when the closure plates have been removed and the process is easy and takes only a couple minutes.
freeflyer
GT Owner/ Forum Sponsor
180
Montana
First class work as always!
86blackwidow
67
Ventura,ca
That is some amazing craftsmanship.
John B
158
Beautiful work!!
I would go without the fans though, they look like more of an obstruction than providing help. I think the point is to duct as much air onto the rotor as possible at high speeds with heavy braking (during a track day). A cool off lap should be sufficient to get things back down to reasonable temps before entering the pits. Not a factor at all on the street.
TallCarGuy
456
Santa Ynez, California
Damn you do nice work Bill. It was a pleasure seeing the start of that project and where it has led.
Richard Hille
The GT School
Very nice !
Well thought out.
As always!
fan assist for front brake ducts
John B - the fans actually are not a restriction below 175 mph. NASCAR uses them on their slower tracks on all cars. There is a lot of wind tunnel testing on the fans & they absolutely help. All my road race buddies have them. I haven't been on a road course where we have hit over 175 mph so they will be fine.
UPDATE
For all the correct reasons I got a little side tracked and then add to this I had to have a couple more pieces powder coated as such I am still tending to the final details as associated with this project however I have now integrated the custom front brake air duct transition manifolds into the front portion of the inner fender liners; yes both of these gal have the front inner fender liners converted to a two piece system; a system that I created and have remained an advocate of for the past few years.
In addition I have finalized the flexible air duct hose length as required within the wheel well; it is 30" and then I had to decide how to secure the duct so that it would be functional, look as if OEM, and also remain easy to service over time because flexible brake ducting does have a service life and this is one far less than that of the gal.
I decided to use JackNuts; these install into a bored hole and then similar to a Riv-Nut secure in a sandwiching manner as they are tightened in position however the JackNuts have a much larger exterior flange (with a serrated underside edge) diameter when compared to the bored through hole diameter and have 4 fingers that extend well beyond the bored through hole on the backside thus insuring a tight fit and cannot rotate or be pulled out, they are nearly flush, and will certainly weather the test of time. To the JackNuts the flexible air duct hose will be secured.
continued.......
