Scratches on Door Sills
I have some scratches on the "brushed" finish of the driver door sill, the inner part that faces the edge of the seat. Anyone found a way to take care of these, short of replacement? The only ideas I have would be steel wool or 3M pad...but sure don't want to experiment. :eek
Thanks.
pauleddy
Owner
306
Newport/Boca Grande
Nice plate...mine is LE MANS 8.
As far as the sills are concerned, try a good quality rouge (compounding) rub and go slowly and carefully. Should work if you don't rush the job.
Kayvan
4,782
You can warranty them; there is a delamination defect in finish...its discussed here somewhere
ViperJoe
1,305
Washington Crossing, PA
I have a new spare set tucked away.
Torrie has them in stock; OR, order custom ones from Jake as seen in other active threads here. They bend very easily coming off, so removing them to service is not an option. Look fors jewelers rouge, but you might start off with tooth paste, the weakest abrasive I know of.
Gulf GT
1,539
Replace and seal with film is what I did.
jaxgt
2,813
Which part are you guys talking about exactly ?
Get some of these they are more scratch resistant than the stock sills !! :thumbsup
Pantera1
281
Iowa
Be careful with that! When I bought my used 05 GT there was plastic on the sills. I don't know if factory or dealer installed but the plastic had been on so long it came off hard and left stains on the aluminum! After trying everything I finally just bought new and replaced them !! :frown :eek
SFLGT
205
FtLauderdale,Florida
I believe KJRGT is referring to the actual sill assy, not the inlay cover.
Hi Guys,
Thanks for the responses...I've been out of town and now just reading them. Yeah, I am talking about the large part of the sill located on the inside at a 45 degree angle of sorts...not the top. And because of what I call a "brushed aluminium" look I don't want to mess them up if I can get the scratches out. So if I go with a rouge or toothpaste, just use a rag and make sure I rub horizontally with the finish?
Either way it probably makes sense to get another set anyway to put them away.
tmcphail
GT Owner/Vendor
4,103
St Augustine, Florida
Yeah I have all of those pieces on hand if needed
jaxgt
2,813
Torrie - can you PM me a price on the brushed aluminum sill mentioned above, and let me know what's involved to swap em
Thanks !
tmcphail
GT Owner/Vendor
4,103
Thanks !
Yes !
tmcphail
GT Owner/Vendor
4,103
Email sent
I just bought a back up set when I first bought the tungsten from Buerge. Just order another pair, then you don't have to worry about a little scratch.
tmcphail
GT Owner/Vendor
4,103
FYI these are all still on hand if anyone needs a set.
