Cooling system notes, Water Wetter
I used to have serious cooling problems with my 535 HP supercharged 1923 Ford Model-T roadster. One thing that made the greatest improvement was using straight water (demineralized) plus Water Wetter (I use two containers). Ethylene Glycol (anti-freeze) is about the worse thing you can add to a cooling system from a cooling performance perspective. It has lousy cooling properties, however, it's necessary as an anti-freeze for many regions of the world. Anti-freeze and Water Wetter both contain additives which reduce electrolysis. This is due to the coolant being in constant contact with dissimilar metals within the cooling system (brass, copper, iron, steel, etc., I know this is off the subject). I use Water Wetter in all of my cars and I usually double-up on the suggested amount. I live in Southern California and do not need to be concerned with freezing temperatures. Under pressure, pure water still has a fairly high boiling point. Why do you think that NASCAR engines are running caps with a >22 PSI relief rating! This means that they are sometimes running their water (and engine) very hot.
Turning the cooling fans on at a lower temperature will not do anything beneficial on the track. It could help on the street by limiting the peak temperature, especially in stop and go driving conditions when the ambient temperature is not too high, say <100 degrees.
Doing an oil analysis on a car that's been "tracked" at 230-240 F, versus a car that's been driven in stop and go traffic at 230-240 F should give different results. I would expect the tracked car to contain much more metal contamination in the oil due to the higher stress levels when pushing everything to the limits. Oil in any car that has been operating at higher temperatures should be replaced more frequently. This is referred to in some owner's manuals as severe driving conditions.
A few GT unrelated notes on cooling engines. NEVER remove the thermostat from your car's cooling system! The car's cooling system was designed with this component within the cooling system path. It is usually a dominant restriction in the system and can prevent the water pump from cavitating on older engine designs, i.e. the SB Chevy. Newer, more efficient water pump designs are more immune to cavitation. NEVER use more 50% ethylene glycol unless you live in very cold temperatures. Your cooling system actually works more efficiently when the coolant is as hot as possible. However, higher temperatures have adverse effects as all of you have discussed.
So, for best cooling performance, use straight (demineralized) water with a product such as Water Wetter. Your engine will run cooler because you are eliminating the ethylene glycol (anti-freeze). Just don't let things get too cold... meaning below freezing!
WARNING! Do not use straight water with WaterWetter in any cooling system that is exposed to magnesium! If you have any magnesium in your system, you must use anti-freeze!
So, does anyone know if there's any exposed magnesium in our GT's cooling system?
One final note, I had used Water Wetter in my '83 DeLorean from about 1986. When I pulled the intake manifold about 15 years later, the water cooling passages were immaculate! Not a trace of corrosion.
