pulling out floor mats
Those nicks in Simon's car are from Molly's spiked heels.
Simon
1,266
She likes flats. Those are my heels!
If you clean up the oozing goo, does it eventually stop oozing out?
Or do you have to disassemble the foam from the rubber and remove it completely to make it stop?
It will always leak. Just the nature of the beast.
Exoticare
Great White North
For Newbies on the site - I have a replacement Floor mat update kit for the GT's.
Update the interior with proper Bespoke mats that fit and are functional with design and can be matched with the quilted door pads.
DM for more details
Reactions: steved57
mmlcobra
1,224
I have the Exoticare floormats.
They are excellent!!!
Best,
Mark
Reactions: Art138
958
Peel all the foam out
I pressure washed the goo out and used some goo be gone
Cut 3 layers of foam to fit and use spray contact adhesive to hold them together and into rubber mat
This is the foam I used. One sheet did both.
Foam Factory
2LB Cross Linked Polyethylene Sheet
72" x 48" x 3/8"
CHARCOAL
There's a lot of goo in them Michael
Reactions: 2112
I just like the weight of the OEM foam so I was trying to see if anyone resolved this keeping the original foam.
Maybe clean out the periphery mating surfaces and seal with 5200?
958
I think what I used IS the factory weight minus the 5#'s of goo.
Look at one of my original foams. A chunk broke off and slid up under another chunk making it 4 layers thick. 5200 might keep it all in the mat but the pieces will still slide all over.
The stuff I listed has flame resistant, low odor and low compressive qualities
