Problems with clamshell struts
Anyone else find a good solution for this issue? It just started happening to my car before i put it in for storage...
How about a poll? Viagra or Cialis?
I can usually raise mine with a thought!!!
haha...Let me know how the poll comes out. I'm 28 and single but it probably cant hurt after 20 ketel & soda's...sorry BONY, I'll switch to Makers eventually. :biggrin
You need strut heaters! :rofl
Man we do today ! :willy
Spring Problem
its common. As far as popping the hatch, There is a spring you can install instead of the little bumpers that will help.
I ordered a set of these but found that the thread diameter of the mounting stud on the original bumpers is larger than the thread diameter of the mounting stud for the new springs. Has anyone who has installed these springs previously encountered this?
Thank you
Thank you
That's correct you need to use a 6mm nut for attachment
Springs
Thank you
NP!
Has anyone with a 2005 installed the clamshell springs from the 06gt and did they help?
yes, that is exactly why I stock and sell them.
As Torrie shared; yes
I have retrofitted many gals with the late style
The process is painless and requires only the two late style springs rather than the fixed point bump stops and two 6mm flange nuts.
I always use a bit of penetrating oil on the originals as they are a swedge lock nut install and I have had a couple where the shafts is; tight and then once removed the late style simply slide into place and then secured by the 6mm nut on the underside.
Thanks Bill/Torrie, I will go on Ebay and order at pair!!!
John
got em ready to roll !
John
You are welcome
Now you said that you were going to order from ????? Ebay
Dare I say that you should simply call Torrie and they will be heading your way
*** I understand now; Ebay aka Torrie's Store ***
All the best
I have a bunch of stuff GT related on my ebay store. So he's good
OK, I am loosing it!!!!!! I know I have seen these parts on ebay for $38 bucks and change, but now I can't find them!!!! Torrie where can I find them???
John
