Possible gauge protection solution
bonehead
2,831
A picture would be appreciated ! (A picture is worth a thousand,... well you know the rest) :lol :lol :lol- surprised our e-Guru Jay did not chime in yet ?
+1. I'm a visual guy.
I don't believe the wires Jay provided are 10 inches long. Hugh, how did you extend it? Solder an extension or connect the Torx to the hexbolt via a separate wire?
33Bravo
688
Minneapolis, MN
Jay?
HPGT
82
Little Rock, AR
I've been short on free time the past week or I would post pictures. Buy a assortment pack of ring terminals(connectors with a hole punched) and use something around 18G wire to bridge the area - crimp or solder the the rings to the wires. I was also hoping for someone to jump in with pictures - If not I will post next week. I picked up connectors at Lowes 20 count assorted ultilitech #0136093 in the electrical dept. around $3.00 Attach one end of the wire with a connector to the original screw and run the other end to the Torx bolt
to the black label on the left side that says "FUEL RESET" with a 1" picture of a gas-pump. I agree a picture is better - but if you get a flash light and extend you head down in the footwell and look to the left - you will see the little gas pump picture.
Good luck
HPGT
82
Little Rock, AR
HPGT
82
Little Rock, AR
HPGT
82
Little Rock, AR
The wife came to my rescue - Leave Jays device connected to the original ungrouded screw and connect one end of your ground wire with connector to that screw. Run the
other end with connector to the Torx bolt - Use the bolt to the right of my black probe wire. I'm going to bed, goodnight.
analogdesigner
951
San Clemente, CA USA
Working on solution
P.S. I just noticed that my first posting that had several photos with instructions has vanished! I am not sure what happened here so I will try and restore it. Jay
Hi everyone,
Sorry for being gone as I was entertaining guests this last week. Right now I am going to carefully read everyone's comments and try to assist in anyway possible. The screw in question has always been a good grounding point for me since I am also using it for my wideband A/F ratio gauge. jcthorne is correct that this device will not do anything unless it is grounded. Thanks all, Jay[/SIZE][/B]
HPGT
82
Little Rock, AR
I just started to hook up the ground and my visual judgement on the bolt was wrong - It is T 27
HPGT
82
Little Rock, AR
Another set of ground bolts on the right
analogdesigner
951
New parts are on order
UPDATE:
I have ordered a box of special grounding washers that should allow reliable contact between the lug and painted black panel while still using the original "7mm" screw as the original grounding fastener. I will have these on Wednesday and will give everyone an update with photos ASAP. I am sorry for this problem. More later, Jay
analogdesigner
951
Solution for grounding gauge protection device
Please go to my original post on this to see the solution that I have come up with:
http://www.fordgtforum.com/forums/s...gauge-protection-solution?p=391687#post391687
Thanks, Jay
GTdrummer
2,130
Richmond Virginia
Jesus, I would rather look at broken gauges than deal with all this sh$t.
HPGT
82
Little Rock, AR
The gauge thing has haunted me from day 1. Every time I drive my car I'm thinking one will go out. Grounding this 1 bolt - regardless of how
you accomplish it - is better than dealing with replacing gauges.
Brombear
1,408
Frankfurt Area, Germany
Jay, thanks for the followup solution.
mopar
171
grosse ile mich
plus 1
DakotaGT
1,730
Sioux Falls, South Dakota
Yes, definitely, thanks. Though this isn't proven, it is a very inexpensive and SIMPLE thing to try. Not a big deal to take another minute to pull the access cover and slip a grounding washer in, sheesh.
mmlcobra
1,228
Thank you!
Geeeeeez. Do your pro bono clients say 'thank you' in the same way??
Unbelievable.
TO AWSUM
Ford GT Owner
1,512
Niceville FL
Unbelievable.
Reminds me of a story about a son and father. The very young son came into the house excited that he had surprised his dad by cleaning his car and wanted his father to come out and look at what he had accomplished. The father walked out, looked at the car, said "You missed a spot on the bumper" and walked back into the house. Nice guy don't you think?
AJK
337
I thought it was discovered that this bolt is not a grounding point unless an additional wire is run to it from the likes of one of the two torx bolts for the console.
