NFGT Battery Charger question
timcantwell
2,639
N.E. OH & Naples, FL
Mercedes SLS has a magnetic charge connector in the trunk.
True. My SLS has this magnetic connector with the same CTek charger that my 2018 GT has. Works great.
timcantwell
2,639
when I purchased mine the three piece set was not available but I also bought a few more sets to try out on other cars. I have not decided where to install it on the 05 yet but it will be somewhere under the car that will be easily reached from the outside for a quick connect. the cool thing about these, is that incase you forget to disconnect them you can drive away and they will just come loose without too much drama.
I can’t tell you how many times I drove away with my charger still connected. I even crushed a CTek charger with one of my tires while backing up. I’m ashamed to say how many cords I’ve destroyed.
Reactions: Ed Sims
This thread is in the 2017+ section.....
Yeah, I know. Just couldn't help myself. it works for me.
jlhoyt
52
SE Michigan
For the people with the 2019's....is the new rear charging port a magnetic one or a something else?
LOVE CHP
330
Central Calif.
It is a 12 volt lighter plug.
jlhoyt
52
SE Michigan
Thanks for the info!
tpraceman
THEE GT OWNER
2,835
Washington Michigan
Trade it in for 2019 ;) Ok a little Frank rubbed off over the years....
Do you guys know there is a new charger coming with the newer cars? It will wake up a sleeping battery.
perfect for 99% of the cars out there if they ever wakeup at all.. however, sleep is overrated
Reactions: Ed Sims
otis
349
Stillwater, MN
Mine has it. The charger has a button on it to surge the battery a small amount to wake it up.
$400 for the new Ctec charger from Ford. I have not seen it anywhere else.
