I was at Willow Springs on Saturday, running the big track in about 80 degree sunshine. Watching the gauges when the temp went up to 230-235. After a lap at that temp, all the sudden the engine shut off. No rev limiter type of signals, just shut off.
Coasted to a slower speed and pulled off the track. After about 30 seconds, I turned on the ignition key and the gauges all switched on. Temp gauge read 230, so I hit the ignition switch and the engine fired right up. Temp, oil pressure, amp, boost gauges all where they should be.
Temp gauge stayed at 230, so I drove easy off the track back to the pits and gauges all were OK. Pulled to a stop, lifted clamshell and could not see or smell anything out of the ordinary.
I ran a search here, as I thought I had once read about the engine shutting off at high temps. However, all I could find was an entry stating the engine was programmed to change timing and fuel mixture so the engine would not hit 250.
Does this mean at 235-240 the engine will respond like hitting the rev limiter, drop in power, or the engine will immediately shut off?
Looking for some advice on how to proceed.
PS. I've been on the track several times and been near these temps before. I have read all about the spring installation designed to keep the coolant hoses from collapsing, but did not think I needed to do it. It will be done soon.
