Anyways I will have the bigest stroke crank in a GT yet as they just finished my 4.350 stroke crank and we will see how it works. 374'' of mod motor fun
Holy piston speed, Batman!
For those who have installed this crank... how far up the RPM range are you comfortable spinning the engine now, with a truly balanced crank.
$4700ish
Fubar if your going to turn the motor over 7000 for extended periods, its not a bad idea to slow the oil pump down.
Spec can be "scary"? There is a little chatter in first gear while it breaks in. Aside from that there is nothing out of the ordinary about the clutch.
Fubar I think you are over thinking all this. Drop the $$$$ on a TT and all you have to do after that is put gas in it and drag your buddies around on the freeway.
