In a private post to me , someone stated the following:
“most cars that have the pulley and tune without any exhaust modification are making about 620 hp to the wheels, so people will not associate the power level to the exhaust.”
The comment above says that all you have to do is add a pulley and a tune and make 620 hp. Although that may be true, it is very expensive and very hard on your motor. Here’s why. First, you have to buy a new supercharger for $8-$10,000 and install it and tune it. Second, you’ve over-boosted the motor.
JBA’s objective was to stay within the perimeters of the way Ford built the motor, i.e., 13-14 lbs of boost. When you over-boost the motor beyond the 14 lbs, you need to run special fuel which is difficult to find when you need it, but more importantly, with 19-21 lbs of boost the head gaskets, intake manifold gaskets, along with the rods, pistons and crank are not designed to take 19-21 lbs of boost. The cool thing about JBA’s headers is you get to the same place for a third of the price and in a boost range that the motor was designed for. Because the motor can now breathe extremely well, the engine will rev much faster and accelerate harder because there is no back pressure in the exhaust system. That’s why JBA headers can make the same amount of hp that others can without putting your motor at risk.
So, it IS the exhaust system and tune that truly makes reliable hp without the risk of doing damage to the motor.
So for those of you with doubts about the JBA headers, and having your car modified and tuned by JBA, I just want to let you know, I am extremely pleased with the way my car performs and I’m glad I had the professionals at JBA do the work.
