It may be little but the condom is still too short. :lolLooks like your GT has a very little dick....
Here's a photo that caught my FGT's pecker exposing itself on the track!
Ice, you may want to burn holes through you tube and cap and put in a cotter pin to keep the cap from falling off.
Methanol is probably even worst than C16. I think it would be great to use for a 80 to 90% oil change if you are running corrosive fuels and don't want to put the car on the lift and remove the belly pans. Just stick a container under the car and turn the valve from the topside. It still would be a good idea to remove the pans once in while to inspect stuff.Clinton you sample your oil? thats an awesome trick and for someone who is running c16 and needs to change the oil constantly is a great tip, really appreciate sharing this.
......................... Funnel seems to be out of production, maybe some still out there.
http://www.griotsgarage.com/product/form-a-funnel.do
I've had good luck with this, which allows me to still use the accufab plugs with magnets. Funnel seems to be out of production, maybe some still out there.
GT Tech version ?
During my last oil change, I installed the Fumoto F107N and it fit perfectly.
