I received these also.....I was under the impression we were getting non-serrated ones because the issue was the serrations would cut into the rubber hose when tightened.Kendell, mine just showed up and these are just standard Ideal hose clamps.
Same. I could have gone to AutoZone and gotten these. What happened to the ones pictured on the website? https://www.cooltechllc.com/ford-gt-parts-accessories/123-ford-gt-fuel-hose-clamps.htmlKendell, mine just showed up and these are just standard Ideal hose clamps.
Maybe I should stay out of this, but the picture shows a "LINED Worm Gear Hose Clamp" that is used for soft hose that can be cut by the serrations. When the clamp is installed the internal extended tail or liner should be under the serrations. If serrations are touching the hose then the clamp is to small. The style of liner can vary by manufacturer.
what am I missing, why not use fuel injection clamps?
Thank you Kendall. Just ordered 2. Hey can I use it as an excuse to come up and see you guys and have the Champ put them on for me???To insure owners can get the correct size and a high quality part, we have added long-tail stainless steel hose clamps to the website. This long-tail version is an improvement over the aforementioned Dorman clamp. The construction is all 316 Stainless steel including the screw. These long-tail clamps insure that there is only a smooth band contact with the hose. You should NOT use the standard serrated clamps as they are likely to cause more harm than good. These clamps should largely be considered as preventative maintenance/insurance.
They can be ordered here: Ford GT Fuel Hose Clamps
Thank you Kendall. I received my clamps and to my own surprise was able to install them all bu myself!!! Thanks GTJoey for the heads up on this...Regarding installation - DO NOT try to remove the fuel line. Instead, just open the clamp all the way, put it around the hose, then get it to re-engage. It should only take a minute or so.
