We're also doing a surge tank but mine is only around ~1.5 gallons I think since it's my old meth tank.Mark i totally missed this thread, I have a full system i designed with a belt pump, tank, return system, fuel rails as im going to run e85 and e98 and make alot of power. It pretty trick the factory pumps feed into a 2.5 tank on the passenger side infront of the rear tire, Belt pump pulls out of that tank and feeds into rails and then the regulator is mounted on that tank and the fuel returns their. The tank @ some point will become over full so then there is a -10 line that returns back to the factory tank. Essentually the factory pumps will just freeflow into the tank. I made alum fitting that goes into the factory fuel line right before the filter and then it goes into a aftermarket filter before entering the new cell.
Later Dan
