front grill
RickM
52
Boise, ID
Best I can tell, Ford eliminated the front grill somewhere between the late 1700 VIN's to early 1800 VIN's.
For those not familiar with the discussion, here are a couple photos of cars with & without the front grill screen.
Thanks,
Rick
AMER SPD
135
Here's some info I've received on the Grill or No Grill question.
______
The new front grille (with the screen deleted) was implemented approximately the end of August 2005 production. This change was made to improve engine cooling under extreme race track use on very hot days. The change also saves a little bit of weight.
Anybody who wishes to purchase this new grille (6G7Z-17B968-AA) can do so through the dealer. The old grille with the screen will work fine, however, and the new grille should be considered if the customer wishes to use the vehicle on a race course on hot days.
______
I hope this helps.
Cheers,
I am confused now. I thought that early cars had grills and later aug 05 cars and on don't have grills, until I read the part about a new grill part number.
Do the new cars off the line have the new grill, or no grill? Do the post Aug 05 cars have the new grill?
AMER SPD
135
BlackICE,
Ford is calling the replacement insert with the larger supports shown in RickM's photos the updated "grill".
Thanks AMER SPD. It seem that the front heat exchanger (I assume for the A/C) is venerable to damage from road debris. One has to be carefull who you are following on the road.
Here in the Valley when it gets good and hot you can't go down the road without finding blown out truck tires, we call them 'road aligators' and they can do major damage to a low car. Easy to avoid during daylight but at night they
are very hard to see. I will leave my grill in.
barondw
1,109
It makes no difference at all.
Dave
Dave
Dave, I am sure I misread, you didn't go to a smaller intercooler? I would think if anything a bigger one would be in order??
Thanks,
daniel
barondw
1,109
Daniel
Great news your sight, reading comprehension, and memory are working perfectly. Yes it was reduced in size.
As you are aware an intercooler is to cool the air flow to reduce detonation. Since I have never had detonation I have never been worried about that factor. But I had high temps, 240, on the track and on the road. Thus I had to do something. In heavy traffic in 90+ / 90+ days (temp & humidity) it would get over 240.
So the following were done back in May 2005: sealed leaks around the radiator, installed a cooler for the transaxle, gutted cats, did the grill change, and reduced intercooler size.
Now its runs 10 degrees cooler under all conditions. So I'm happy.
Dave
Thanks Dave, no doubt, I not your technical match, and I am grateful to learn new information. Especially, since I live in the Cadillac Dessert where summer tempertures soar. Chances are I will need to follow your lead. Thanks. :wink
I always thought the cooler the air for the blower the more horsepower you make? I have had issues with a former Benz where I needed a bigger intercooler and there was not enough space available.
Going to a thread at the start of this forum I told you about the Cal-Smog-Nazi's and the rolling smog checks that I have seen in my little town of Fresno. For me gutting the cats, or headers and Borlas is not an option.
Have you ever mucked arround with WATER WETTER, some folks swear by it?
canibl
446
Sacramento, Cali
I use water wetter regularly in my shifter go-kart as do many top go-kart drivers and it does keep the engine a few degrees cooler....but again I'm only talking about a $1,000 Honda one cylinder engine generating 34hp, 80cc. I would actually ask an actual race car driver/mechanic what additive they use to keep water temp down.
FlorIdaho Chris
Yeah, I've got one.
Dave
Dave-
Gutted cats? Do you get a CEL? Any other changes to the exhaust? Does it sound much louder now?
Thanks, -Chris
Several engine builders I know swear by it, other laugh it off. I use it in my other cars. Will use it in the GT if I feel I have a heat issue.
barondw
1,109
Bony
No I have not used water wetter. I have heard pluses and minuses as you have.
Yes the larger the intercooler the better, but if there is not airflow that's a whole different situation. Also the intercooler was not reduced by that much.
Dave
barondw
1,109
Florida Chris said:
Dave-
Thanks, -Chris
Chris
There are a couple of threads on this subject. There is no CEL because you insert resistors. Any decent speed shop can get them and install them, Viper and Vette guys do it all the time.
As to sound yes its louder, more resonant, and somewhat annoying.
Dave
