Fire extinguisher mounting
06gt1858
154
Lodi Ca.
Yes the seat is all the way back and useing stock mounting thork bolts to mount it, the finish work matches the interior of the car..
Steve
Also when the unit is removed by the quick pin release the seat will move all the way up with the bracket still mounted on the rails , this is truly a nice ad on!
Ripper 02
Permanent Vacation
Aug 16, 2006
229
Steve
I spoke with Steve at Livermore....
With the Extinguisher mounted there is some limited travel in the far forward
seating position. As far as sliding the seat rearward there is no problems at all.
Great bunch of guy's to deal with.... I have one of these on the way !!!!
06GT1858 ,
Thanks for the post's !!!!!!
06gt1858
154
Lodi Ca.
06GT1858 ,
You will be pleased!:thumbsup :thumbsup
Steve
Thank you Gents for all the info, particularly on the seat mounting/movement. I just ordered my kit.
I'm a big fan of anything polished, but with a black GT, and seeing the pictures of your black halons, there was only one choice, the powder coated black extinguisher.
According to Steve at Livermore, more seat brackets are in production, scheduled to complete this week.
UPDATE: Seems there is a backorder on the QR brackets for the extinguishers...
According to Steve at Livermore, more brackets are in production, scheduled to complete this week.
just ordered one from steve:thumbsup
sharp33
347
Rochester, NY
Why are we not trying to do a group buy on this also? IMHO this is the minimum that we should have in our GTs. Even Porsche offer a fire extinguisher as a factory option of many models. And as someone smarter than me pointed out, the extinguisher can be used to smash a window in case the door cannot be opened.
Edson
103
Santa Monica
I would be interested in a group buy. Count me in for one.
There is a back order list already. Steve seems like a very decent guy. Ed Sims is responsible for the design according to Steve, THANK YOU ED!:thumbsup
06gt1858
154
Lodi Ca.
I second that , thanks Ed for getting me the second one of the line YOUDAMAN!!!
Steve
Thanks for the kind words
My patient Dave Thornhill is the fabricator. He cut Steve's & my fire extinguisher bracket by hand but has just finished 20 of them this week using a water cutter. They should be even cleaner which is difficult to believe. It's really a very simple design. Dave has done amazing fabrication & welding on all my motorcycles & cars the past 15 years.
Steve & his brother, Monty, at Livermore Performance are very cool. They both are serious gear heads that open track all the time.
My wife rode in the GT recently & didn't even notice the fire extinguisher below her legs! That's a good sign. Thanks Steve & Bony!
Ed, thank you for your many contributions to the FGT Community!
Gulf GT
1,539
Again, thank you Ed.
sharp33
347
Rochester, NY
Question: Are most people mounting the fire extinguisher in front of the driver or passenger seat? Can it be easily removed and used from the driver's seat if it is mounted on the passenger side?
06gt1858
154
Lodi Ca.
passenger side mount , pull the pin marked "pull" and out it comes into your hand smooth as butter....quick release pin works perfect and you can't see the unit unless you look for it , its a real nice install SEE PICS at beginning of this thread.
Hope this helps you
Steve 06gt1858
sharp33
347
Rochester, NY
Hope this helps you
Steve 06gt1858
Thanks Steve. I just wondered if anyone tried mounting it in front of the driver's seat since there was a mention of using it to smash a window in the case of an accident that prevents opening the door.
06gt1858
154
Lodi Ca.
I think the braket made would fit on either side but with unit in place you cant move the seat forward
What size torx bit (T45? or T50?) are you using to remove the bolt to mount the extinguisher bracket to the seat rail?
What method? Socket with angle head? Looks a little tight with the seat cushion almost over the head of the bolt.
T50
I cut a T50 down as short as possible and put it back into its 3/8" drive rachet holder. Then connected it to a long wobble extension. The extension compresses the cushion, but it has a smooth finish and didn't cause any damage.
Also use hand tools, it will be a lot safer, not the Makita.
Pete S.
529
Imo
Re-using the standard seat hold down bolts diminishes the strength; as the number of threads that do the work are many fewer. If any of you want, I bought a bag of 30mm long bolts and decided to get a heavy flat washer for each: I used 2, so have enough for 9 more installations (18 bolts & washers). Instead of Torx, it is now a 7mm allen head. Send me a PM or e-mail if you'd like a set. I'm sending a set off to Ed for all his great work on these Livermore extinguishers.:cheers
Pete S.
All I need is an address to ship them to.
Mine was installed last night, looks great, hope I never have to use it.
Thanks Livermore and Ed Sims:thumbsup
