YES, YES AND YES, Depending if the tank is 3/4 full, cycle runs ect. Wind up is before you get KILLED in the car replace the pipe, BELIEVE ME YOU WILL KNOW THE DIFFERENCE..... When you pull the pipe out flip it up side down , blow in the pipe , it will pass air just from you alone, its a combo , possible cracked pipe where the return line is, possible , top lid sticking where the fuel goes in , also BOTTOM FLAP UNDER PIPE YOU CANT GET TO. JUST REPLACE IT , ITS A BIG, BIG SAFETY ISSUE, P.S i WAS HESITANT TO DO IT CAUSE MY MOTOR IDLED AT 625 LIKE A FLAT HEAD MERC, YOU SHOULD BE AT 650 TO 700 , THE DROP SOUNDED GOOD BUT IT WAS DUE TO VACCUUM LOSS , NOT VERY GOOD ON HILLS, BRAKES , CLUTCH PRESSURE ECT. JUST DO IT BABY!!!!!!!!!!!! GTJOEY 1314 AND LOVING IT. :thumbsup
