engine kills
Now Im trying to figure out whether to cancel a track day i had setup on the 21st.
Ask yourself this question: "If, due to this pblm, my GT suddenly looses power on the track at a most unwelcome moment, what kind of damage might I expect as a result?"
The answer to your origional question lies in the answer to the latter one.:cheers
kumar
1,011
Dallas
well the power outage has never happened above 5mph in my case and im pretty sure in anyone else's case either
I believe your can build a tune that will cancel the purge test and disable the error code, then problem will go away. However you will not be in compliance with OBDII and the smog police!
My guess would be to change
MAX load for Purge test to 0.001
and
MIN load for Purge test to 1.999
Then the purge test should never happen. You might also have to disable the purge test error codes too. I am not sure of the code, but maybe P0456 or 457.
Caution, I never tried this, so discuss if with your tuner more accuarate information.
Pls see post #1 'this thread.
gtjoey
Keep Smiling - GT Owner
3,454
OLD POST, IF CODE 442 COMES UP , SLOW EVOP LEAK ,ITS THE PIPE!!!!!!!!! BEEN THERE , MISSED AN 18 WHEELER BY INCHES, VERY DANGEROUS!!!!!! PLEASE READ OLD FILLER PIPE THREADS, DO NO DRIVE THE CAR!!!!! JUST ASK DAVISP AND ALL THE REST, ANNND YES THE FENDER IS COMING OFF. BE SAFE NOT SORRY!!!!! THANKS GTJOEY 1314:thumbsup
