- Aug 8, 2007
- 5,256
12000 miles. No body work. Sounds like the same problem as your door. I just lift a little as I close the door to keep from rubbing on the top right corner of door frame (receiving) as I close it.
ok sounds like the same thing, Im going to tell you something and you might think Im crazy, ....... when I said I gently lift on the door I didnt mean I lift a bit to clear then close the door, I meant I lift with enough force (gently) to actually bend the metal where the hinges are connected to, this seems to solve the problem for about two to three weeks then it slowly come down again,
Disclaimer, Im not telling to bend your door, just telling what I did!!!!!!
