As long as you have oil pressure within a second or two of starting, and you get full oil pressure above idle, you're okay. But I also am curious about where/whether that second O-ring goes.
Yay! Thanks HHP. Bonehead-please note the O ring size. The one in your pic is too smallI would caution you using the BMW cap and cage as purchased. You will be dumping pressurized oil into the crankcase.
See my post below.
FGT vs BMW Oil Filter Cap & Cage
In the late 90's and early 2000's some plastics used for Genral Motors hot engine parts deteriorated and crumbled. These problem plastic parts were changed to metal. With this in mind, I thought it might be a good idea to have a spare oil filter cap and cage assembly for my FGT, since, I could...www.fordgtforum.com
The confusion occurring in this thread is the old heads describing/using the old Ford/BMW filter kit and not the new designed Ford/BMW filter kit. The old filter kit design contained the large (softball sized) O-ring and a copper washer, the new filter kit eliminated the copper washer and added a small (dime sized) O-ring. In the old filter design, you threw the copper washer away and only used the large O-ring since the copper washer was for a BMW application. I would not replace the green O-ring with the small black O-ring unless it is damaged, but always replace the large O-ring with the new one included with the new filter. This is why the Ford Manual only shows the large softball sized O-ring, because the green O-ring is not to be changed. Of course, if the green O-ring is damaged, then see if the small O-ring fits.But do you put that small O ring on the plastic cage?
It’s clear but all the descriptions of what is actually in my car and what was included in the packaging are different from what’s being described. I’ll admit I didn’t pay too close attention to how many O rings were on the bayonet nor did I differentiate whether or not the small piece included with the new filter was an O ring or a washer (yes, I know the difference, I just didn’t look that closely nor am I the one that put it on). To my knowledge, the bayonet has never been changed and am not sure why it would have since it’s not a disposable wear item.Bonehead, a washer is not the same as an O-ring. A washer is a flat surface formed in a circle, an O-ring is a round surface formed in a circle. You should only have one small O-ring on the bayonet. The large O-ring seals the bottom of the cap to the housing. Two total O-rings should be used -- one on the bayonet and one on the housing. Remove all others. I don't know how we can make this clearer to you.
Certainly possible as in the 10 years I’ve owned this car, this is the first change I’ve done myself. I would have to assume there are hundreds of cars out there running this BMW part because of the scenario you described. I’m definitely no engineer but I’d fine it hard to believe that such small differences in the part could cause such catastrophic problems as long as oil pressure is maintained.I seem to remember back in 2005-6 when the GT was introduced, some mechanics threw the snout away with the old filter because they thought it was a disposable unit. Maybe someone did that to your engine and substituted the cheaper BMW part. You'll soon know.
Was that wrong? I gave it a good wipe down before I put it back in the cabinet.You're gonna get your as s kicked for using your wife's weekend China.
You are correct, the o-ring near the end of the bayonet is not needed. Having it installed does nothing, no harm.Well, this was killing me, so I couldn't wait until the weekend to figure this out. Pulled the filter and.....looks like I have some mish-mash of kits. Mine has both O-rings (but theses are orange/red, not green) and the plugged port hole between the O-rings. First pic is what I pulled out. And yes, my mistake, the kit I received had a small crush washer, not an O-ring, which you can barely see to the left of the O-ring closest to the filter. I promptly removed that. Second pic is the plugged port hole. Third pic is after removing the second O-ring; this is the final version of what I installed. I don't know how long I've had this bayonet with both O-rings. Car runs like a champ and I've never had an issue with oil pressure. I'll have to assume (at least for my peace of mind) that the presence of that second O-ring doesn't matter. But I defer to the wisdom of the Forum gods on this one.
That was from a thread you had posted https://www.fordgtforum.com/forums/threads/fgt-vs-bmw-oil-filter-cap-cage.36556/You are correct, the o-ring near the end of the bayonet is not needed. Having it installed does nothing, no harm.
That does look like the OEM bayonet. What was the picture you posted of the BMW bayonet with the hole???
