Anyone has problem filling up the gas tank?
maxemus
886
Miami, Florida
Sorry for jumping in without reading the whole conversation but I have had similar problems in south Florida. Sometimes It just keeps kicking back and stopping the flow. Doesn't always happen though
richardson221
19
My flap is broken. I can see it hanging down. Causing gas to back up and turn off nozzel. How did you fix. New assembly is expensive
Mike
HeritageBruce
Where have you been? Like you dropped off the face of the planet. I have the same problem. Usually it happens at Chevron Stations. It if the pressure sensor or some connection with the Chevron hose and nossle. I don't have the problem with other stations like Shell, or 76. Try getting gas at another station if you are using Chevron and see if the problem is still there.
EJ
Wwabbit
1,259
Knoxville, TN
There was a thread here a while back from a member who claimed that the flapper simply gets knocked off its hinge in the filler neck. A pain to get to, must remove fender liner and access from wheel well. According to him he was able to reattach the flapper and all was good. I'll look around for the thread.
BelgianGT
382
Belgium
The day before yesterday I had to fill her up and it took such a long time. A long time ago somebody found a fix from another ford car but forgot Which car. Need to get it fixed one of these days. The pistol always jumps offf
bonehead
2,827
Filler assembly from an F-150
http://www.fordgtforum.com/forums/s...uel-Filler-Fix-solution-found-and-engineered&
The Grey Ghost
692
Kansas City
It can be snapped back in, but does require disassembly. The key is, while it's apart, to improve on the keeper that holds it in place so it doesn't pop back out again.
