Yes, and some the "technical experts" triple post.
Frank, as I was making my post(s) there was a “server problem” and it would not show me if my post had been processed and added to the thread. I notified Dave and he must have edited out the duplicate (or triplicate) posts. Thanks DBK.
Indy, I have a question for you Bill. Why would a tri-metal bearing be better than a bi-metal bearing? I wasn't aware that even two different types of steel were used in bearings let alone three. I don't understand that and you can probably explain it.Chip
Thanks Chip, let me try, with appropriate acknowledgment of reference material from Obert’s book on Internal Combustion Engines and Air Pollution and Shigley’s book on Mechanical Engineering Design:
Typical engine bearings must be designed to possess a number of design attributes:
1. Friction- It should have low friction coefficients in relation to the shaft materials.
2. Scoring- Is should not abrade or seize the shaft material and, preferably, it should be able to operate with unhardened journals.
3. Strength and Fatigue- It should retain its strength throughout the temperature range of service without flow, cracking, or fatigue, and it should be able to withstand shock loads.
4. Embeddability- It should be able to absorb abrasive particles that would otherwise score the shaft.
5. Corrosion- It should not be attacked by either the oil or oil contaminants, nor should it catalyze such attacks upon neighboring material.
6. Plasticity- It should be able to conform to the shaft, especially in the break-in period.
7. Bondability- It should adhere or bond with its backing material.
8. Thermal Conductivity- It should be a good conductor of heat.
9. Adaptability- It should be readily machined or cast, and be inexpensive to produce.
Modern day Internal Combustion (IC) engines typically use bearings constructed with multiple layers of differing materials allowing tailoring of the bearing to its specific service application and optimization of the above listed design parameters. Present day bearing construction uses steel or bronze inserts which fit into engine block/rod-end support structures, although steel backed bearings have largely replaced the bronze base since the layering materials bond better with steel. Bearing inserts can be produced within close tolerances, and therefore bearings can be replaced without additional fitting or surface scraping to achieve desired build clearances.
The steel insert is usually “tinned” with a bonding agent and the bearing layer materials applied to the steel backing by either casting, sintering or pressure bonding. “Babbitt” or white metal bearings are a general term that refers to either a tin or lead-base alloy of various metals. Babbitt bearings are now almost exclusively used in modern gas/diesel engines. The tin base is usually preferred for heavy duty applications as the tin (and lead) is soft, with a low melting point that enables the alloy to flow and relieve misalignment, while the additions of copper and antimony to form an alloy provide the necessary strength. Babbitt is popular because partial failure allows plastic flow and the bearing can still function; and with complete failure, little or no damage may result to the shaft. Obviously with a loss of lubrication or outright fatigue failure of the bearing layers (resulting in increased running clearances and elevated impact shock loads) the crankshaft or rod-end journal can be severely damaged. Moreover, the tin-base and most lead-base alloys resist corrosion. Lead-base babbitts have not been as popular as the tin-base, because lead is susceptible to attack by acids in the oil.
Chip, all this to say the bearing has a singular steel backing with multiple layers bonded to this backing which are the actual “wear” materials. Depending on the bearing design and manufacture preference there can be two, three or a number of additional layers applied to the steel backing which is what you are questioning.
Hope this helps give you a better appreciation of your engine internals……:wink
