05/06 Power Steering Hose Deterioration
JOETWINT
441
Brooklyn N.Y.
I just came across this thread looking to purchase another hose for a friends Heritage. After reading that the new return hose is failing in the same fashion as the original I went to check my GT . I can confirm my new replacement hose is weeping just like the original. Any updates on new hoses that don’t fail?
I've had two of the after market ones go bad - the "original" and its (free) replacement. Apparently not a peep from the supplier since last September .....
B.M.F.
1,834
Minnesota
The only way to get a hose that won’t seep is to build a silicone hose and they kinda look like they are wrapped like you would wrap something with electrical tape etc. Unless a hose is made with some sort of liner a rubber water hose which was used by ford will not work or last and they will always bleed oil as they are not designed for oils.
Could this be made to work? Titan UFW Ultraflex 2SNK Braided Hydraulic Hose. Min bend radius 3.5 inch.
Maybe this is a good option?
Johntpr
243
Rockland County, NY
