Has anyone experienced slight warping of the rear clam shell's black lip/fin? Mine has a slight warp to it.
Should be relativley easy to make an aluminum (or Titanium :biggrin) replacement.
I got mine replaced and painted under warranty. If I recall, once you remove the fasteners that holds that piece in place, it ruins the bolts and you'll end up having to replace the entire piece.
Someone should make a CF piece..and offer a version that is a little taller than stock.
I'm not sure a larger wickerbill is advisable unless you want more downforce.
