Switch Lights Out
My Headlight switch and Foglight switch light bulbs are out.
I found the part numbers for the switches.
Do I need to replace the switches or can I just pull them and replace the bulbs?
Thanks. :thumbsup
I don't believe there are bulbs. I think they are LED. new switches do brighten up the situation for sure!
The bulb is integrated into the switch as Scott says. A bit fiddly to swap out - you have to take out the whole switch assembly with all the switches on it. Lower dash off first then go up from underneath.
Thanks guys.
I've been putting it off because the steering wheel blocks my view of those two switches.....but having something on my gal that is not right keeps nagging at me!
