Stock GT suspension?
BasillioG
21
Phoenix
I need to raise my car a bit to clear my driveway. Is this the stock suspension? Anything I should be aware of?
My front wheel well to ground is currently 26 7/8 and rear is 28 1/16 so I need to bring everything up perhaps 3/4 of an inch.
Thanks-Brian
extrap
1,896
Gainesville FL
Oooof I cringe at the thought of a higher GT stance, since I think they look better lower than stock, but I digress: The 4G7V-5560-AA7 model in your pic is the same as mine below; sorry, I don't have any info on raising one.
69b302
114
Upstate NY
You could have adjustable/drop perches, but hard to see lower spring perch in photo.
Depending on where the drive way has the issue , Have you investigated the heavy rubber wedges that can be purchased to “fill in “ between pavement and curb to allow for a smoother “transition?
Several homes in my subdivision use them.
Andy (ajb)
939
Add a lift kit? I think a kit was for sale not too long ago too.
JOETWINT
438
Brooklyn N.Y.
The shock/spring in the pic is stock but it has the adjustable aftermarket perch installed.It looks like from the pic it can be adjusted up at least 3/4 of an inch.I would guess the car has been lowered from stock already since usually thats the reason the adjustable perches were installed.
Reactions: DakotaGT
DakotaGT
1,714
Sioux Falls, South Dakota
this...
My advice is fix your driveway entrance
Simon
1,263
Yes. These “bridjit curb ramps “ are what I referred to earlier and what my neighbors us.
Andy (ajb)
BasillioG
21
Phoenix
Thanks for all the input. The issue with my driveway is not at the curb, it's at a break over in the driveway because I'm on a hillside lot and the street is approximately 20' higher than where my garage is located.
Here is a better picture of the shock perch. Someone mentioned that the spring is original to the car and perhaps the shock but the perch had been updated to be adjustable. Anyone recognize the brand? I don't have the wrenches to adjust and tried two different generic sets of coilover adjustment wrenches and cannot find a set with a round peg on the end for these perches.
For those with a recommendation to install a set of Scott Ahlmans shocks, I'm on the list that's 20 deep, likely mid year 24'.
Howard
1,149
Florida/North Jersey
Will this work? https://www.stage3motorsports.com/803-00-732-fox-25-coilover-spanner-wrench.html
Also, you could just grind down the square peg of a less expensive wrench until it fits in the round hole of the adjuster ring. Lube the bottom of the spring where it contacts the adjuster ring.
I'd be happy to loan you the tools you need to adjust those perches. PM me if interested.
It’s not the car that needs the fix!
