- Aug 25, 2006
- 4,436
PPI is short for “Pre-Purchase Inspection”
Now when the gal’s were being sold new through the Ford dealerships this process as a secondary event was not necessary because as the gal was assembled someone signed off as to her good health and then the selling dealer was instructed to give her a once over just to make certain that nothing was missed furthermore a bumper to bumper warranty was part of the process for even greater peace of mind.
However now that the gals are being sold on the secondary market with many of them nearing the 4 year old mark the stories and associated concerns are ever present hence the reason for a qualified and IMO thorough PPI. Now let me state at this time; IMO the typical Ford dealer cannot properly complete this task because they were never trained on these gals; certainly there are a few however in the end it comes down to the individual rather than the facility. Get to know who is massaging the gal.
Having been associated with the automotive industry for far too many years to remember I have to share that the PPI process often times is little more than an exchange of value; meaning for a couple hundred dollars a facility will on their letterhead create a document that states something to this affect; we inspected this car and “near as we can tell the gal is in great shape with no signs of damage”. Now I am being overly simplistic because most will have a basic check list however the key phase is “near as I can tell” which is a disclaimer thus absolving them from downstream liability should issues be found at a later date. Then add to this CarFax has become a source for data however it can only share that which was presented and in the world of high end exotic cars many incidents go unreported because of the potential adverse affect on values; just remember that to a person every seller has the perfect gal.
So what does a person do when considering the purchase of a gal in the $200K priced range? IMO I feel that when considering a F-GT or ?? there are typically a small hand full of people that understand the gals and know what to look for; meaning just because her skin is smooth and shiny does not me that she has not been banged around and furthermore just because she fires and runs smooth does not mean that there are not underlying issues.
I think that a proper PPI inspection is a bit of an insurance policy and should be considered an investment in the process. I also feel that one should be prepared to pay for a PPI knowing full well that the results may present data that moves them onto a different car hence it is an expense that protected rather than produced.
Having said this IMO here is the greatest issue when it comes to PPI’s; the associated cost. If you call around a typical inspection is a couple hundred dollars and even at this price point many folks bow their necks and yet at the same time are akin to a kid in a candy store ready to write the $200K check; this has never made any sense to me. How much effort would you expect to be put forth during a PPI when the cost of this process is so little?
As an example here is what I look for when the gals visit my facility without even performing PPI; abnormal tire wear at a solo corner, unusual panel fits, is the proper hardware installed throughout the gal (indicating that she may have been taken apart), the small vin stickers on every panel, meaning the doors, fenders, bonnet, clamshell, etc. If I open up an area and find them to be missing I share this with the gal’s owner. I have found more than one gal with no such vin sticker on a front fender and when mentioned there was also NO reported history that this fender was replaced prior to them purchasing the gal and yet rest assured it had been. It is the law that the vin stickers be furnished on the panels and are NOT available for replacement panels.
So when it comes to asking for a PPI on a gal that you are considering the purchase of you need to know who is going to do the inspection; I hear people say all the time that “the seller took the gal to ?? and got the PPI inspection for me and I they even paid for it”; now this seems more like the means to assure the sale when compared to protecting you. When I hear this I quietly shake my head.
A proper PPI requires that the gal is initially driven so as to garner data about her feel on the road, that all systems operate properly, and any associated noises heard during the process noted for the next phase of the inspection. Then she needs to be placed on a lift and the under body panels removed, the wheels removed, the inner fender liners removed, and the door panels removed. Once this has happened all vin stickers will be found and secondary paint and or body work becomes exposed. Now assuming that all items within these areas pass then she is reassembled and then the fluid levels and visual conditions are checked followed by the removing of the spark plugs. They are visually inspected and then compression test is performed. I say compression test because in order to do a leak down the gal needs to be at operating temperature and to complete all 8 holes requires a restart mid way through the process as such I will complete a compression test and then based on the result decide if a leak down is needed to isolate a concern.
The key to a quality PPI is the honest and comprehensive collecting of data to be shared; now there is nothing to say that finding out that for example a fender was replaced is a bad thing or ??? however the knowledge of her true condition based on days gone past becomes the basis of her present value and potentially her future.
So can this process be completed for a couple hundred dollars; no and to expect such is silly and one would be better served to purchased the gal with no PPI as the odds remain the same and you will have saved the couple hundred dollars.
The moral of the story; if it sounds to inexpensive it likely is and if based on little or no front end investment you expect full disclosure then you are setting yourself up for a fall.
To complete a proper PPI on a F-GT or ?? is a 8-10 hour process for which one should expect to pay $1-1500.00. Now if this seems like a large amount then I dare say that considering a $200K gal must be an extreme consideration.
Consider this; because the number of these gals is extremely limited and their value continues to increase the number of resurrected gals will increase and many will be sold by brokers that in truth do not know her history.
In closing I suggest that to a person you are very careful out there because as time goes by the associated risk when considering such an investment goes up furthermore and sadly; BT Barnum lives and the world of salespeople and their stories will never cease.
