Rear Toe Link replacement
Tomcat
The first step is to: "...remove AND DISCARD the outer toe link nut, then remove the bolt". Later I need to remove discard the inner toe link nut.
I guess I need to have a new bolt/nut (outer, what spec?) and new inner nut (spec?) as the new toe links (4G7Z-5B551-A) did not come with additional nuts or a bolt.
Thanks,
Tom
Tom, not necessary. They are not TTY. Clean and reuse the original ones and torque to spec.
I have taken mine out several times to clean and lube the joints and replace the deteriorating boots.
Reactions: Tomcat
