Rear Badge for the GT
tanner
96
Thanks for the link.
Art138
631
Weston,FL
Heres the GT Ford badge!
Can the lettering be offered in other colors i.e GT in White and Ford in Blue???
RPM217
2005 white/blue stripe
Jun 18, 2010
1,664
Rye Brook, New York
Why does it say "Falcon" in the description?
FENZO
1,518
Lafayette, CO
It is a part from a Ford Falcon, note "GT Ford badge" not a "Ford GT badge". Check the first post of this thread.
AZGT
1,354
Scottsdale, AZ.
Nice to see that after 4 years the badge idea is still a good one. In 20 years new buyers will ask "why is the badge missing" since so many cars have them .......
OK, Mine came.
How is everyone attaching them? By that, I mean what means are you using to hold them onto the rear grille?
The two posts appear to be designed to accept a body style pinch nut but the diameter is pretty large for the first 3/4" preventing a pinch nut from bottoming out against the backside of the grille.
Art138
631
Weston,FL
OK, Mine came.
I also received mine yesterday and today did the install: I tapped the upper lower poles to accept a 10MM bolt.....I used aluminum bolts as the cast poles are fragile. I carefully cut some felt strips to prevent scratching on the badge backside. To provide a firm fix black washers were used so the bolts would not press on the mesh opening. After hand tightning the bolts (through the license Plate opening) used a 10mm box wrench to give them a gentle nudge. I would not over tighten....
Did yours come in the Tampon box too? :biggrin Aussie humor I guess. :cheers
Did you turn down the thick part of the shaft before cutting the threads? I am imagining the cast pot metal can break pretty easily.
Thanks for the blow by blow.
The Grey Ghost
692
Kansas City
Mine did!! I thought it was a little odd, but if they all went out that way.....................
They must be buying them by the pallet.
Hope to install mine this weekend.
Jeff
Art138
631
Weston,FL
Correct, also using a dremel drill,the pole leads were cut off - leaving the thick portion of the poles for cutting; pot metal material is tolerant to tapping.....
tanner
96
Mine was in a tampon box too. I found some humor in it.
If the key chains become available in white and blue I would take 2.
AZGT
1,354
Scottsdale, AZ.
They go on with a speedy nut - self cutting and holds firmly. They don't need to be super tight. Put a gasket behind the badge so you don't scracth the grill.
OK, Mine came.
AZGT
1,354
Scottsdale, AZ.
After being at Rally 13 and seeing some of the GT badges I sold back in 2008 - 2009, I went looking on my shelf and found the remainders of what I have. There are 3 left.
They are $50.00 mailed.
I painted the "Ford" blue on mine, many did get the car color on them. They are a nice touch.
I don't know if my "supplier" is still around since it has been 13 years since I bought them. If other members want them past the available 3, I will see if I can get more.
We used to joke that in the future people will think that they were OEM since so many were around. I finally met that person .... :)
KennethClay
883
New York
Just PMd you. I'll take one.
pacettr
102
Mustang, OK
I definitely want one please!
Shark01
599
Yes, they were still for sale on Ebay last time I looked....I bought a different variation.
centerpunch
ex-GT owner x2
952
OH/NC
It's an Australian part, google: Ford XW GT Falcon Grille Badge
extrap
1,898
Gainesville FL
I painted over the emblem's factory orange with red fingernail polish, but that didn't turn out to my satisfaction so I used fingernail polish remover to remove it, which also removed the orange 😯 so now the G and T are chrome ... and actually I'm happy with that on my Quick Silver. Hard to photo chrome, but here's a try: (please excuse the dust; she's just back from Arizona 🌵 😉)
Reactions: Nafod
GSix
52
Chicagoland
That looks way better!
Reactions: extrap
