Inner door frames
dougnshari
51
Derby, KS
I took my aluminum door frames off on both drivers and passenger sides to get them painted due to having a small scratch on the drivers side. I am very ANAL! They are double taped on with clear thin tape. Does anyone know where I can get this tape, I want to use the same as the factory used. Thanks. Do not have pc at home so it is best to call me at 316-788-5967. :cheers
Pete S.
529
TSB 05-19-9 a
1. Fully separate the aluminum trim ring from it's plastic substrate. Use care not to bend or scratch the panel.
2. Prepare the plastic substrate panel by removing all tape residue and apply a generous coat of adhesion promoter (3M Part # 4298UV) to the entire surface.
3. Allow the adhesion promoter to dry for at least 1 minute and apply new strips of 1" wide(25mm) double sided tape (3M Part #9495LE) according to the illustration (Figure 1). The tape must be applied to the plastic substrate within one (1) hour. If not, the adhesion promoter must be reapplied.
4. Prepare the aluminum panel by removing any existing adhesive or tape. Ensure that there are no bends, nicks, or scratches that would inhibit adhesion between the aluminum ring and the plastic substrate.
5. Align the aluminum trim ring with the plastic substrate and press together. Ensure good contact between both panels by applying firm pressure around the perimeter of the ring.
6. Remove the eleven (11) existing retaining clips . . .
the rest is for the early 05 panel repair. You should be able to find everything at local paint shops, or auto parts stores.
Good luck,
Pete S.
AZGT
1,354
Scottsdale, AZ.
I did mine with double side mirror tape right from Home Depot. Works better than the original since it is a little thicker. The thin stuff the factory uses requires a perfect fit - the mirror stuff is a little more forgiving.
gtjoey
Keep Smiling - GT Owner
3,454
TIP OF THE WEEK.... FORGET PAINTING THEM, CALL YOUR DEALER TELL THEM THEY FELL OFF AND THEY WILL REPLACE THEM WITH NEW ONES:thumbsup AANNNDD THEY WILL HAVE THE UPGRADE RETAINING CLIPS SO THEY NEVER FALL OFF AGAIN!. COMMON WARRANTY ITEM, THEN KEEP THE OLD ONES FOR SPARES. GTJOEY 1314 AND LOVING IT:thumbsup
dougnshari
51
Derby, KS
Thank you all very much for the help. What if you bought car from private owner? I know the private owner bought from a dealer close to his home located in Florida. I was going to have a friend of mine who is a airbrush artist paint them to look like carbon fiber. Thanks. Doug 316-788-5967. :cheers
STUNTS
2,438
I'm probably wrong but the wrranty should cary over as long as its in its perameters.... 3yrs 36k miles.... blah blah blah:rofl
FlorIdaho Chris
Yeah, I've got one.
No Ford warranty for owner generated scratches.
I used a thicker tape just like AZGT and had good results.
bgb27
Active member
Jan 26, 2007
42
not for scratches but joey says if you say they fell off you get new ones
FlorIdaho Chris
Yeah, I've got one.
I am not a proponent of lying to Ford and/or making a fraudulent warranty claim.:bs
If they fell off and got scratched, make the claim. If you hit them with your foot and scratched them it is your own problem. If you can afford to own a Ford GT, you can afford a few bucks for a new piece of aluminum trim. What ever happened to doing what is right?
For the record, I am not in favor of committing insurance fraud either. :bored
I bet he doesn't speed either! Damn republicans.
FlorIdaho Chris
Yeah, I've got one.
I am also not in favor of victim-less crimes. Speeding is A-OK in my book as long as you don't endanger others. No victim = no crime :wink
Not Republican...Libertarian. :thumbsup
I like it. I'm using it the next time I get pulled over.
Do you accept collect calls... I may need someone to get me out.
SteveA
GT Owner/B.O.D
3,697
Sandpoint Id
Uh-oh....here we go.:eek
Thinking the same thing....
Hey!!!!!! I resemble that remark!!!!!!!:skep
('Looks like Steve & Spec were right!:lol )
C'on fellas, a little angst in the morning is good for you.
Show me the AMA confirmation!
SteveA
GT Owner/B.O.D
3,697
Sandpoint Id
Anyone see Hillary on South Park last night? OMG!
'Saw a clip of it on O'Reilly, I think it was.
THEY HAD HER DOWN TO A "T"!:lol
AMA?
You mean the American Music Awards or the Academy of Model Aeronautics?
